E4OD question
Old May 4, 2022 | 05:43 PM
icrman's Avatar
icrman
E4OD question
Just wanted to see if this happened to others. Did a short drive to pickup some stuff, started up a slight hill, selector was in D range, out of nowhere it went into neutral I made a quick look and yes in D, I immediately pulled it into 2nd, and all was good for the last 600 feet to the persons driveway. It ran and shifted okay on the home trip. Check fluid level and in the good range. I have never had that happen before. Any idea's?
Old May 4, 2022 | 09:43 PM
jk080's Avatar
jk080
Transmission Rebuilder
Sounds like a bad MLPS switch, see if any codes are stored for the transmission it can give you a idea on what might have happened.
Old May 4, 2022 | 10:53 PM
icrman's Avatar
icrman
Codes likely gone since the bat is disconnected when not in use.
Old May 6, 2022 | 05:26 PM
icrman's Avatar
icrman
So if the MPLS goes out will it still do the limp mode? I guess stays in 2nd gear? What about reverse?
Old Jun 29, 2022 | 01:25 PM
Jamie1212's Avatar
Jamie1212
1st Gear
2001 f150 crew cab 5.4 4x4 have e40 tranny what other tranny can I replace it with an what years
Old Jun 29, 2022 | 08:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't know what an e40 tranny is. You probably mean E4OD. If so, that's not the transmission that came with that truck. The last year for the E4OD was 1998. Your truck would have had either a 4R70W or a 4R100.
If you want to replace the trans with a different type of trans have a LARGE pile of cash on hand. That is a very expensive change. You'll need new wiring and a new computer.
bart f-350
May 15, 2016 07:13 AM
George D.
Jun 29, 2010 07:25 PM
andy316
Nov 17, 2008 07:55 PM
91f1502wd
Mar 10, 2001 12:25 PM
