05 powerstroke non start
Old Jun 10, 2025 | 05:27 PM
xIJoshF150Ix's Avatar
xIJoshF150Ix
Hi all
New 6.0 powerstroke owner here from the UK
Bought the truck from Copart in March and just got it here last week
When I bought it there was no sign of the engine running, as the batteries were flat so they have been replaced.
However I am getting a strong crank but no start situation, as soon as the oil pressure is up the truck tries to start but won’t, with around 200 revs
- i have checked the FICM which is 48.5V on run and cranking so that is good
- Good oil pressure which rises when cranking
- fuel pump is running under the chassis rail
- plenty of fuel in the secondary filter (although it does want replacing- just waiting on replacements) and raises fairly quick when cranking
- injectors all seem to make a noise when ignition is on run
- ICP has been unplugged and still won’t start, however on my snap on computer the duty cycle of the ICP is 35% and volts fluctuate from 0.7V to 1.3V and the KPA ranges from around 4000kpa when cranking.
My initial guess was the ICP sensor was faulty creating a non start situation as everything else looks to be good.
I have read the codes, do have a U1900 code for the instrument cluster but nothing else for the engine except Glow Plug Circuit 2
Someone mentioned downloading ForScan, which I did and these are the results, looking on other forums the IPR is either shot or leaking, however the ICP seems to have a strong reading.
Would anyone be anyone be able to point me in the right direction either the IPR faulty or an oil leak?
I did notice a small puddle of oil on the floor yesterday.
Thanks
Old Jun 10, 2025 | 05:35 PM
bismic's Avatar
bismic
The VPower dropping to 9 volts is a problem.
You need 150 rpm minimum when cranking.
You also need cam/crank Sync.
Also, you need to remember that a FICM can be bad and still pass a buzz test and still producing 48 volts.
Old Jun 11, 2025 | 01:40 AM
kbeefy's Avatar
kbeefy
yeah, that voltage drop is pretty steep.
Might try with the glow plug controller disconnected, or measure amp draw on the starter to see if you have a voltage drop in the start circuit.
Whats FIPW and fuel pressure?
Old Jun 11, 2025 | 01:41 AM
kbeefy's Avatar
kbeefy
Can you have FICM sync without cam/crank sync? Just asking for my own knowledge.
Old Jun 11, 2025 | 04:20 AM
bismic's Avatar
bismic
Yes, it can and does happen.
Old Jun 11, 2025 | 04:39 AM
xIJoshF150Ix
what is the FIPW? Sorry I’m new to these trucks and I will test it on forscan again.
Old Jun 11, 2025 | 05:02 AM
amthatiam's Avatar
amthatiam
Fuel injector pulse width, below is a guide with more information about FICM's hope this helps
https://www.ford-trucks.com/ford-man...ch%20Guide.pdf
Old Jun 26, 2025 | 01:09 PM
xIJoshF150Ix
Hi all
Sorry for the late reply I have been busy and not much chance to look over it
im not happy with the Vpower & Lpower being so low, I have had brand new batteries on the truck and fully charged them, does anyone know what the cause for low voltage could be?
I have tried a new ICP & IPR and neither looked to have helped
on the second graph at the bottom I have put on the Fuel injector Pressure in Ms
i don’t know if that is good or not really!
I would appreciate any help as I am lost with it!
thanks
Old Jun 26, 2025 | 01:28 PM
bismic's Avatar
bismic
We mentioned that you need 150 rpm and also Cam/Crank SYNC. Please tell us specifically what you are getting for these parameters.
Also, as suggested by @kbeefy , did you try disconnecting the GPCM when cranking?
Old Jun 26, 2025 | 01:37 PM
xIJoshF150Ix
I am getting around 200/250 rpm on the dash when cranking, it tries to start and shakes the truck but doesn’t.
Sorry what is the best way to check cam/crank sync? I am using forscan.
I tried disconnecting the GPCM and there has been no difference the V power & L Power are still the same
Old Jun 26, 2025 | 03:03 PM
bismic's Avatar
bismic
ForScan will show the PID for Cam/Crank SYNC. It will also show the actual cranking speed so you do not have to watch a fairly inaccurate dash gauge.
You also need to scan for codes with ForScan.
Old Jun 26, 2025 | 03:23 PM
xIJoshF150Ix
Okay I will have a look tomorrow and report back.
i have scanned the truck I am only getting a U code for the key
Thank You
Old Jun 26, 2025 | 04:13 PM
kbeefy's Avatar
kbeefy
Add ficm sync, cam/crank sync and rpm to your forscan graph.
You might just have a weak starter causing that voltage drop, but your getting enough rpm and voltage for the FIPW to fire.
I'd check fuel pressure. Theres a test port for a manual gauge on the filter housing on top of the engine.
Old Jun 26, 2025 | 05:03 PM
TooManyToys.'s Avatar
TooManyToys.
Since these are new batteries, what size are they?
Old Jun 27, 2025 | 01:59 AM
xIJoshF150Ix
They are 700cca each and 95AH. This is the biggest I can find in the UK to fit the truck!
