Starter removal
Old Jun 6, 2025 | 04:54 PM
tico47's Avatar
tico47
Starter removal
Hi everyone, Last week I picked up a 1949 F1 in real decent shape. A few minor problems that I am working on. I would like to remove the starter and have it rebuilt as it seems to have a dead spot from time to time. Two outside bolts easy to get at, then there is the bolt on the other side tucked in between the starter and the oil panWhat is the trick in getting at this bolt. . I have tried my 3/8th and quarter inch drive socket sets and cannot get into where this bolt is located. I am open to suggestions, thanks in advance
Old Jun 6, 2025 | 05:01 PM
mtflat's Avatar
mtflat
There are only 2 long bolts that go thru the starter body. Do not take them out, only loosen from the block plate and hold the starter together as you pull it out. For what it's worth, I put nuts on the threads of the long bolts as soon as I get it out. If the starter comes apart, you need three hands to reassemble it. Guess how I know that!
edit: I just looked at my 6 cyl and your description makes more sense now. You're removing bolts that will disconnect the clutch housing from the block plate. You want to remove the two bolts on the end of the starter. IIRC it takes a 7/16" socket.
Old Jun 6, 2025 | 05:58 PM
51fred's Avatar
51fred
When I bought my 51 with the 226 6cyl., it would lockup and not be able to run the starter. I had to put the truck in 4th gear and rock it back and forth to move from that spot.
It turned out to be the fiber timing gear.
Just something else to think about if the started rebuild doesn't solve your problem.
Old Jun 7, 2025 | 07:54 AM
tico47's Avatar
tico47
Thank you for your input, I will give it a try
Old Jun 7, 2025 | 07:57 AM
tico47's Avatar
tico47
I had this problem with in 1950, back in 1964. This is a little different as the starter seems to have a dead spot from time to time, so I would like to remove it to have it rebuilt. Thank you for your input
Old Jun 7, 2025 | 11:42 AM
tico47's Avatar
tico47
Okay, now my question is if I remove those two bolts from the starter, will this also remove the starter bendix drive as I want to repair both?? thanks in advance for your help
Old Jun 7, 2025 | 02:59 PM
mtflat's Avatar
mtflat
Yes the starter and bendix are one unit, but are not held together by anything more that the 2 thru bolts.
Hold the case together as you wiggle the bendix around the flywheel. You usually have to lean the starter body toward the engine.
The bendix gear/spring assembly sits behind the flywheel and pulls into it when you hit the starter.
The "cup" that shields the bendix is what you see behind the bellhousing and it does not come off.
Old Jun 7, 2025 | 03:30 PM
tico47's Avatar
tico47
Okay, thank you for your help, it's been many years since I did one of these and at the age of 78 I have to ask for advice. Thank you again
egchewy
15
Aug 22, 2022 05:55 PM
L9000 Fire Truck
Large Truck
Apr 30, 2017 07:44 PM
Daniel_3168
Feb 6, 2016 12:59 PM
CrewCabLongbox
Jan 7, 2014 12:59 PM
buckford
Jan 28, 2004 10:07 AM
