Wrong bed?
Old May 6, 2025 | 12:44 PM
Kman-S.E.USA's Avatar
Kman-S.E.USA
Wrong bed?
I do know the previous owner swapped this bed. I ordered a 1975 f100 tailgate (Ford Tooling Spec) through Dennis Carpenter. Is this how it should look when closed or is this a bed from a different year truck and it needs a different tailgate? All the lines are lined up, so there is no adjusting this anymore. It fits so much better than the cheap one I bought of Amazon, lesson learned.
Old May 6, 2025 | 12:48 PM
somethingclever's Avatar
somethingclever
As I said in your other post - I think you have a bunch of filler in that corner.
(and maybe the other side too)
Old May 6, 2025 | 01:25 PM
Kman-S.E.USA
It's at least 1/2" thick of bondo on that one side, the other side is pretty close. I guess I have more surprises coming when I sand it down! I'll get this in the works this week. Thank you and I appreciate all the help.
Old May 6, 2025 | 04:39 PM
tbear853's Avatar
tbear853
Bumpers that move it rear wards wouldn't hurt. They came with bumpers, yours looks like the TG goes in too far at the top.
Might be some adjustability in the hinge mount holes too.
That right side looks like whomever did the filler contoured the shape a little too sharp too.
'73-'79 use the same TG.
Old May 6, 2025 | 05:07 PM
Kman-S.E.USA
Good catch! It came with new bumpers I have not installed yet and the old ones are about shriveled away. I'll put them on and adjust it best I can and go from there.
Old May 6, 2025 | 05:51 PM
440 sixpack's Avatar
440 sixpack
Once you get the bumpers in and pull it back where it belongs you can fit it with 80 grit. get some bondo off there.
Old May 8, 2025 | 10:03 AM
F-250 restorer's Avatar
F-250 restorer
Trying to reshape that corner with 80grit is going to take all day. I would use 24 grit grinder to rough in the contour, then would come the 80 to smooth it out a bit before reapplying bondo to get it how it needs to be. Be constantly raising the TG to check your shaping. Finish with 120 grit and primer.
Good luck.
P.S. I hate to say it, but I wonder if the real surprise is going to be what you find under all that bondo! I would remove the tail light and take a looks see up in there. I wonder, depending on what you find, if it might be easier/better to find a corner at the J/Y and weld it in.
Old May 8, 2025 | 10:26 AM
tbear853's Avatar
tbear853
I was looking yesterday at mine same corner with TG down, I could get my finger under that corner with ease, is a narrow lip.
Old May 8, 2025 | 11:41 AM
Kman-S.E.USA
Good luck.
I believe that's probably where this is headed. I'm in no rush, so all the surprises are just part of the learning curve.
Bigfin
Jun 20, 2022 08:57 AM
Big-Red-Lariat
2015 - 2020 F150
Sep 17, 2020 10:00 AM
AlsRyd66
Jan 7, 2018 01:27 PM
Eallend7
Oct 22, 2012 06:23 PM
GigAg04
15
Sep 29, 2010 01:39 PM
