Fuel Pump Recs?
Old May 6, 2025 | 01:35 AM
Petedeol's Avatar
Petedeol
3rd Gear
Fuel Pump Recs?
Hello everyone,
I recently purchased a 95 F-150 5.8L with dual tanks. I am having an issue where when I run the rear tank, the front tank overflows. What I’ve read so far is that I need to replace the pumps. Though I don’t know if the sender valve comes with the pump kits or is that separate? Or am I completely off base here?
Also if anyone has any recommendations on which fuel pumps they have had luck with or no luck with, please share.
thank you!
Old May 6, 2025 | 05:57 AM
JJF20's Avatar
JJF20
Unfortunately, I don’t think you’ll have luck finding Motorcraft anywhere, maybe NOS on eBay. They discontinued them a couple of yrs ago.
Spectra, I’ve used and was ok other than noisy, I replaced it with a Motorcraft. A couple other off brands as well, but no longevity out of them, and I don’t remember the brand names - cheapo parts store pumps.
If I had to choose right now, I’d go with Delphi.
I’d also buy the whole FDM, pump and sender complete. Rather than trying to reuse the old sender with a new pump. Hang onto your original Motorcraft part though.
FDM = Fuel Delivery Module
Rockauto = Fuel Pump and Housing Assembly.
Old May 20, 2025 | 09:47 PM
Petedeol's Avatar
Petedeol
3rd Gear
much appreciated!
Old May 21, 2025 | 08:05 AM
jmtbiggin's Avatar
jmtbiggin
I just did both on my 91 2 years. Every pump on rockauto that "fit"my truck did not have built in check valve. They would've been fine for a single tank. I lucked up on ebay and got two OEM old stock
Old May 21, 2025 | 08:34 AM
Hit Man X's Avatar
Hit Man X
TI Automotive are good pumps, they make Walbro now. I just tossed one in my Vette and the Civic, seem fine.
The '92 has Delphi as does the '88. Actually the '01 Screw too I think.
Old May 22, 2025 | 10:06 AM
Squisher's Avatar
Squisher
Until you fix it just run your front tank down/out first and then switch to your rear. By the time the rear is done you'll have a 1/4 to 1/2 tank in the front again. No overflowing. I've operated my 95 like this(only reversed) for the last decade atleast and neither pump has given out or caused any other issues.
Aus f150
May 22, 2025 10:02 AM
bailey teague
Feb 13, 2022 10:27 AM
Vellu
Dec 13, 2018 05:37 PM
The96Beast
Jun 16, 2018 02:27 PM
spiffy
1997 - 2003 F150
Jul 28, 2009 08:52 PM
