Fuel System Issue
Old Jun 13, 2018 | 06:25 PM
The96Beast's Avatar
The96Beast
Fuel System Issue
So I have dual tanks on my 96 F-250 351W. I just recently replaced the fuel pump in the rear tank and some other issues have developed when I use that rear tank. There is a loss of power under load and today it stalled on the freeway under acceleration. All of the wiring looked good the connections to the tank are solid. None of these issue are present when I use the forward tank. Are there fuel regulators or fuel relays for each tank? I'm fresh out of ideas and I don't want to burn a brand new pump up. Thanks for any help.
Old Jun 14, 2018 | 03:28 AM
TexasGuy001's Avatar
TexasGuy001
I would check fuel pressure while running on each tank and see if it changes between them.
Old Jun 14, 2018 | 06:36 AM
subford's Avatar
subford
Sounds like a bad front pump module (valves) in the forward tank.
No there is not separate regulators or fuel relays or fuel filters for each tank.
Why did you change the rear pump module?
Old Jun 14, 2018 | 01:54 PM
The96Beast's Avatar
The96Beast
I changed the rear pump because it had the same issues, but much much worse. It could have been a combination of a weak pump and this valve issue. Now that there is a brand new pump, that leaves the front pump. Will a fuel pressure test confirm the failure of this valve? Can it be fixed by dropping the front tank and replacing the pump or is this valve assembly separate?
Old Jun 14, 2018 | 06:30 PM
subford's Avatar
subford
Maybe.
More than likely.
Old Jun 14, 2018 | 08:06 PM
Conanski's Avatar
Conanski
I think you just have a faulty pump in the rear tank, what brand was it? Anything but Motorcraft is basically a crap shoot, some of them last a year, some a week, some a DOA right out of the box.
Old Jun 16, 2018 | 02:27 PM
The96Beast's Avatar
The96Beast
I hope it isn't bad! I got it from Rock Auto, but I'm not sure what brand it is. I just got a fuel pressure gauge, so I'll test it today. Meanwhile, the truck won't even running off of the rear tank now. It just shuts down.
Boss F150
40
Jul 18, 2016 07:31 AM
w6pea
May 21, 2013 03:34 PM
LADNAR
Feb 24, 2011 09:24 AM
somethingclever
Jan 26, 2009 04:56 AM
Ford_F-250_1990
Oct 5, 2006 01:28 PM
