Sponsored by: Real Truck
trans help needed
Old Apr 27, 2025 | 02:33 PM
Kennerdell8's Avatar
Kennerdell8
6th Gear
trans help needed
Hi, long time viewer, first time poster.
I recently purchased an 06 f250/6.0 for my work truck, runs great, developed a 3-5 flair so i decided to change the direct solenoid as well as all the others, the filters and valve body gasket. After putting it all back together, now it will not move in reverse nor forward, fluid is Mercon LV filled properly however after testing my pressures i have 30psi in park, 25psi in reverse and 25psi in drive/3/2/1. Any help would he appreciated, i know Mark is out here looking somewhere.
~Jake
Old Apr 27, 2025 | 07:48 PM
Kennerdell8
6th Gear
Update ; now have a po720/722 code for OSS, sensor tests good and harness looks okay. Haven't ohmed it.
Old May 1, 2025 | 10:14 PM
droldsmorland's Avatar
droldsmorland
5R110W trans I will assume.
Those pressure readings are deathly low.
Did you verify the valve body (vb) gaskets were a 100% match?
Did you torque the vb properly?
Is the filter properly seated in the vb?
Verify the solenoids are installed properly.
Something is cross leaking or just plain leaking badly.
Where are you tapping in to read the pressures?
You could try swapping the old solenoids back in to see if the pressures come back to spec.
Old May 1, 2025 | 10:30 PM
Kennerdell8
6th Gear
i ended up pulling the trans and installing another this weekend.
Old May 2, 2025 | 10:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
~Jake
No, I wasn't. I was on vacation with no internet access.
When you checked the fluid level, was the trans warmed up, in park, and the engine idling?
Old May 2, 2025 | 10:27 AM
Kennerdell8
6th Gear
Yes it was up to temp, in park and running
ptmarszalek
Jan 18, 2020 10:31 PM
RhondaBruce
Oct 7, 2010 06:48 PM
plowin4u
Mar 6, 2010 04:31 PM
Warhippie
Dec 7, 2009 09:17 PM
csmallwood
1983 - 2012 Ranger & B-Series
Feb 15, 2007 03:59 PM
