4R100 trans. issues
Old Dec 7, 2009 | 02:17 PM
Warhippie's Avatar
Warhippie
4R100 trans. issues
Howdy all
Ok here you all go. I just rebuilt my trans and installed a new torque convertor. My problem is that when you go to put it in drive it won't pull and the overdrive OFF light flashes. It hooks great in reverse and in M1 and M2 but won't pull at all in drive. Im confident that it isn't the pump as it takes more line pressure in reverse and M1 than drive and like I stated it goes into rev. and M1 great. I pulled the valve bodies off and disassembled and reassembled them today. They looked and functioned great. I'm at my wits end trying to figure this one out so I would greatly appreciate any suggestions anyone might have.
Old Dec 7, 2009 | 02:59 PM
big poppa's Avatar
big poppa
Looks like a question for Mark Kovalsky, he's our trans expert here..
Old Dec 7, 2009 | 03:19 PM
Warhippie's Avatar
Warhippie
Thanks so how can I get intouch of him?
Old Dec 7, 2009 | 03:37 PM
big poppa's Avatar
big poppa
You can do a search or just hang tight, he should be by later on. Here's a bump, we have other members here that can help you too..
Old Dec 7, 2009 | 04:26 PM
mueckster's Avatar
mueckster
Since you have the OD light flashing, have you checked the trans codes stored? These codes would help point you (and us) in the right direction. Did you air test all the clutch packs to see if they applied OK before you installed the valve bodies?
Old Dec 7, 2009 | 05:27 PM
Warhippie's Avatar
Warhippie
No I didn't but when I get home from work tomorrow I plan on tearing back into it and shooting it with air. As for the codes I don't have access to a code reader and am in the country so getting it to a source isn't an possible.
Old Dec 7, 2009 | 06:43 PM
nissandoc's Avatar
nissandoc
I think Roland is on the right track. Probably rolled a seal and have an internal leak.
Old Dec 7, 2009 | 09:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be a one way clutch installed backwards. I've seen that before.
Warhippie
13
Dec 18, 2018 04:09 PM
Fordfanatic69
Jan 3, 2013 05:09 PM
afbrian13
Modular V10 (6.8l)
Jan 7, 2011 12:41 PM
278broncos
Mar 26, 2010 11:33 AM
bubbasz1
Mar 15, 2009 08:53 AM
