Trans trouble (C4)
Old Oct 6, 2010 | 08:15 PM
RhondaBruce's Avatar
RhondaBruce
Trans trouble (C4)
My truck will not shift into a forward gear. It used to have a delay from when I shifted into drive until it actually engaged so I decided to replace the fluid and filter. Well, upon installing the new filter I installed what I believe to be the pressure relief valve backwards and continued with the job. Well, I drove it and it was having problems shifting into 3rd. Then it had problems shifting into 2nd, then finally it wouldn't move forward, reverse only. I realized the pressure relief valve was *** backwards so I put it where it is supposed to be. Nothing changed. I don't know if that spring and pin being backwards did some detrimental damage to my trans or if this is an easy fix. I have a feeling if I tow it to a trans shop they will tell me it needs rebuilt or replaced even though it could be an easy fix. It is a shallow pan 11 bolt c4.
Old Oct 6, 2010 | 08:45 PM
Flat_Ford's Avatar
Flat_Ford
i've been through several C4's in my other car and usually when it would only go in reverse the trans had crapped out completely...i once had to drive about a mile in reverse to get home.
Old Oct 7, 2010 | 06:48 PM
RhondaBruce
i really hope thats not the case. i was hoping i could salvage the trans without a rebuild.
Adamjmerideth
Oct 29, 2011 02:58 PM
Hermann Bratbecker
Jan 27, 2009 02:23 PM
JerZ79
Dec 21, 2008 05:47 PM
marnie1989
Feb 2, 2008 03:48 PM
bf5113
Jun 10, 2006 06:13 PM
