Brake controller
Old Apr 22, 2025 | 05:41 PM
ehusmann's Avatar
ehusmann
Brake controller
1993 F150 extended cab, 5.0L: Looking for recommendations for a plug and play brake controller. Thanks
Old Apr 22, 2025 | 05:55 PM
Hit Man X's Avatar
Hit Man X
Do you have factory tow pack? Otherwise not 'plug and play'
I like Curt stuff.
Old Apr 22, 2025 | 07:41 PM
TobyB's Avatar
TobyB
Having been here without the factory tow package-
SOME of the wiring is already there.
The cab has the controller wires in the harness,
but underhood and along the frame does not.
You end up adding pins and wires to the chassis side
connector, and it's kind of a pain. If I had to do it again, I'd
avoid the factory wiring and instead add my own.
If you HAVE the tow package, adaptors are almost plug- and- stop-
I like the Tekonsha, myself, and that requires attaching it to a universal pigtail.
t
Old Apr 22, 2025 | 09:58 PM
ehusmann's Avatar
ehusmann
Hit Man X: Owned truck for thee years. Truck has a tow bumper and seven pin plug that plugs into wiring harness. Does not have extra transmission cooling.
Old Apr 23, 2025 | 08:07 AM
wwhite's Avatar
wwhite
My truck had tow package and plug for controller, but was missing the blue wire from fire wall.
it may look like plug and play but won’t be.
i ended up getting a true variable 2008? Ford brake controller that works off a pressure sensor on the master.
really depends on how often, how far and how much towing you plan on doing.
Old Apr 23, 2025 | 09:20 AM
Hit Man X's Avatar
Hit Man X
Factory tow will have the extra relays hanging off the fuse box for the trailer brake
Look to see if that seven pin is OE or aftermarket. Tow pack had the HD cooling system, sway bars, etc.
Old Apr 23, 2025 | 09:53 AM
wwhite's Avatar
wwhite
Not if previous owner(s) have removed it.
Old Apr 23, 2025 | 09:57 AM
Hit Man X's Avatar
Hit Man X
Fair point but they would have to depin the fuse box and remove the harness down the frame to totally remove it.
Old Apr 23, 2025 | 11:18 AM
wwhite's Avatar
wwhite
My old truck had tow package, sway bars, not hd cooling, external trans cooler, single core rad, was missing the relays and wiring.
I ended up getting all wiring from a junk yard, was a pain to pull, but wanted it like factory.
Old Apr 23, 2025 | 11:24 AM
Hit Man X's Avatar
Hit Man X
You buy it new?
I added sways to the 88 and 92, plus did HD cooling.
Old Apr 23, 2025 | 11:52 AM
ehusmann's Avatar
ehusmann
Thanks everyone for replies. I do have a Tekonsha that I had used on another F150 that would have to be hardwired. Unfortunately it is in a box in storage. Storage unit is scheduled to be emptied in three weeks. Someone mentioned how much towing which would be very little and the heaviest would be a 1964 Triumph Spitfire @ 1500 lbs plus trailer.
Old Apr 23, 2025 | 01:35 PM
Hit Man X's Avatar
Hit Man X
Keep us posted, this will help others in the future
Old Apr 23, 2025 | 05:48 PM
ehusmann's Avatar
ehusmann
It will be a few weeks but will post progress.
Old Apr 24, 2025 | 08:03 AM
wwhite's Avatar
wwhite
The trailer I tow has hydraulic surge brake tongue on it, not electric.
I wouldn’t even bother, sure it helps, but your going to be under 2500lbs with that combo.
when that much weight goes in the box you don’t put extra brakes on the truck, right?
Old Apr 24, 2025 | 08:46 AM
AuroraGirl's Avatar
AuroraGirl
well weight in the box isnt behind your truck and then suddenly attempting to push it when stopping
But its well in the safe range as well
If its pulled often, the brakes give the option to stabilize the trailer if it were to be sway-y, and it wears the truck brakes less
Jonesy0027
2015 - 2020 F150
Dec 19, 2019 09:58 AM
bama210
Modular V10 (6.8l)
19
Mar 13, 2009 10:58 AM
RÖENTGEEP
Apr 21, 2008 01:49 PM
Hiflyer746
16
Oct 4, 2007 09:28 AM
CC'sDad
Feb 25, 2005 06:33 AM
