Add Trailer Brake Controller
Old Dec 13, 2019 | 03:38 PM
Jonesy0027's Avatar
Jonesy0027
Howdy,
Purchased my 2019 truck new in September. My truck does not have a tow package or trailer brake controller.
Wondering how much it would cost to add a trailer brake controller?
Appreciate the input.
Old Dec 13, 2019 | 04:23 PM
GlueGuy's Avatar
GlueGuy
The 2018+ F-150 has a slightly different TBC than earlier years. Getting it installed is not too big a deal, but you should be aware of a couple of gotchas outlined here.
Old Dec 17, 2019 | 03:35 PM
JASinILL2006's Avatar
JASinILL2006
You can add a Ford brake controller or an aftermarket controller that will plug into the same harness. I have a Tekonsha P3 proportional brake controller (about $100) and a special adapter ($10) for the P3 to connect to the Ford brake controller harness plug under the dash. Took me about an hour to install it.
I can't speak to the performance or cost of the Ford controller (other than LOTS of folks think it is excellent), but I can tell you the P3 is also highly regarded, highly customizable, and easy to use. I have had mine for quite a while - it was on previous F150 - and it has always worked flawlessly. I think the Ford controller gives you some integrated features (and a ready-made slot in the dash) that make it an attractive offer, but I don't know the details. I was happy enough with my P3 that I didn't look into the Ford controller.
Old Dec 18, 2019 | 10:10 AM
GlueGuy's Avatar
GlueGuy
The main advantage to the OEM controller is that it integrates with the console in front of the steering wheel, and it applies braking proportional to the brake pedal pressure. Almost all the after-market controllers (like the Teconsha) is that they need to be mounted level, and they apply brake pressure relative to inertia.
Old Dec 19, 2019 | 09:50 AM
JASinILL2006
That is interesting. I can see how the console integration would be nice (although I'm not entirely sure what all that gets you), but it seems like the inertia controlled-braking would not be much different... I imagine that brake pedal pressure is highly correlated with deceleration (which drives the inertial controller). Do the integrated controllers just have better responsiveness?
I don't tow heavy -- just a 19' I/O fiberglass boat on a single axle trailer -- so I generally don't notice much difference in breaking with my trailer attached or without. I do have my P3 adjusted pretty well for my trailer, though, I think.
Old Dec 19, 2019 | 09:58 AM
GlueGuy's Avatar
GlueGuy
The main difference is when the trailer brake is applied. With the OEM TBC, the trailer brakes are applied at the same time as the TV. With the inertial systems, the TV brake is applied before the trailer brake. The sequence is a bit of a safety issue, and is probably more important with heavier trailers.
mullis68
2015 - 2020 F150
May 22, 2017 10:27 AM
F2250crew
Oct 21, 2014 04:39 PM
iggy2
6.2L V8
Feb 28, 2011 07:27 AM
Birdhunter1
2004 - 2008 F150
Aug 8, 2004 11:26 PM
99pwrstoke
All Things Towing
Apr 16, 2004 10:02 AM
