NO FUEL TO INJECTORS
Old Feb 22, 2025 | 01:02 PM
Evancortis's Avatar
Evancortis
3rd Gear
Currently working a fuel issue on my 93 f250 I’m getting fuel to my IP but not out of it my FSS clicks as it should I’m lost on what to do
Old Feb 22, 2025 | 11:08 PM
ihc1470's Avatar
ihc1470
How do you know that you are getting correct amount of fuel to injection pump? Tell us how you verified that please. What is condition of fuel filter and fuel? How many miles on current fuel system. What conditions does the truck have that leads you to believe you have a fuel issue?
Old Feb 22, 2025 | 11:13 PM
Evancortis's Avatar
Evancortis
3rd Gear
I have pulled the lin going to the IP and it’s gettifn a steady stream of fuel and i pulled the line going to the filter and its getting a steady stream of fuel
Old Feb 22, 2025 | 11:14 PM
Evancortis's Avatar
Evancortis
3rd Gear
Filter has about 4k on it and I just put new injectors and caps and lines on the other day
Old Feb 23, 2025 | 08:21 AM
tjc transport's Avatar
tjc transport
i ain't rite
proper fuel delivery to injector pump out of filter head is 1/3 pint in 10 seconds cranking time. also minimum 7 psi fuel pressure out of fuel filter to injector pump.
Old Feb 23, 2025 | 09:24 AM
ihc1470's Avatar
ihc1470
What condition is the injection pump in? A tired pump will have a hard time building the pressure needed to crack nozzles that are up to specs. I replace both at the same time.
Old Feb 23, 2025 | 01:50 PM
6.9_4spd's Avatar
6.9_4spd
Originally Posted by Evancortis;[url=tel:21499822
21499822[/url]]I have pulled the lin going to the IP and it’s gettifn a steady stream of fuel and i pulled the line going to the filter and its getting a steady stream of fuel
have you cracked the injector lines to see if any fuel comes out?
Old Feb 23, 2025 | 04:53 PM
tjc transport
i ain't rite
^^^this ^^^
new injectors will kill a tired injector pump almost instantly.
6.9_4spd
Nov 28, 2024 09:48 PM
bewildered 7.3
6.7L Power Stroke Diesel
Feb 7, 2024 06:07 PM
mknapik
Jan 12, 2014 12:52 PM
70T351W
Aug 28, 2008 01:29 PM
