no fuel
Old Jan 12, 2014 | 08:55 AM
mknapik's Avatar
mknapik
no fuel
Put everything back together after cleaning carbon out of injector bores and cleaning them up and now I'm not getting fuel past IP . It has been sitting about two months and worked before my motor replacement. Any thoughts to why this is happening thanks again
Old Jan 12, 2014 | 11:01 AM
wtroger's Avatar
wtroger
Are you getting fuel out of the filter? Normally you have to to crack the lines loose at the injectors and roll it over until you see fuel at the injectors before they will even think about starting.
Old Jan 12, 2014 | 12:52 PM
mknapik's Avatar
mknapik
Getting fuel to IP just not out of it cranked it six times and had all injector lines cracked . Checked fuel shut off its working . Any way it can be clogged or to clean it out.
97F250LD4X
Jun 14, 2010 11:49 PM
Paul26
Oct 23, 2008 05:24 AM
70T351W
Aug 28, 2008 01:29 PM
