2017 F250 4x4 E-Locker Switch Remove/Replace
I used my e-locker switch last night and when done pushed it back in but the light stayed on...and rear diff is definitely locked. Can push the button and bezel and it goes away if held in. I'm certain the switch broke at the top screw as the bezel doesn't fit tight to the dash now.
Looking for the best way to remove and replace the 4x4 e-locker switch? Is it a fair guess the switch is held in with locking tabs to the opening? If so is it easiest to break the bezel to get to the tabs? Or is there some other far too complicated way this switch is mounted and different route required to remove?
Thanks in advance!
Britt
https://www.fordpartscatalog.com/oem-parts/ford-switch-assembly-fl3z14b166ba?c=Zz1ib2R5JnM9Y2x1c3Rlci1hbmQtc3dpdGN oZXMmbD0yMSZuPUFzc2VtYmxpZXMgUGFnZSZhPWZvcmQmbz1mL TM1MC1zdXBlci1kdXR5Jnk9MjAxNyZ0PXhsdCZlPTYtN2wtdjg tZGllc2Vs
https://www.ebay.com/itm/204864061529?_skw=Ford+%28FL3Z-14B166-BA%29&epid=22037365839&itmmeta=01JKS7DZ9A738J5YFA5 AQGPJGT&hash=item2fb2d98059:g:ydMAAOSwK2lmbFsT&itm prp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1eP8CKSxrfP ViCFmE9Ko7f6CFn%2FPuxhMiPG2FIPZMtHyTM5Ie5xeYzPtcMs yBeBf17RSnkfdGXVEKG8WJ1S7uoYaIkbWxL0DofU3Ycd453PJ1 wHH4ApKqDNZ%2FC3hC8aRuWLNmoWlob44rhYeuHtr6sqBiQGPY Canu%2BzddlBQQmDJXdCio8ENGIk1%2FNXGA8obShB7JnGGE7A kUhBRwrVLGEs4diz2A%2FV2SYAurgljigQBK%2F9m5pxWTsgtS bNDvRFJspp3Nmqe1WdDEm8hzT18kTQI2QrU6bSNV41THKBxKxN NA%3D%3D%7Ctkp%3ABFBM6PS3p55l
It is held in by 3 plastic spring tabs but you can't get to them because of the bezel. I wasn't about to tear apart the dash for something that was broke anyway...so I pried on it at the top and bottom of the bezel until it came apart...and then the spring tabs were easily accessible! New one on the way and will be back in tomorrow. Pic for shear satisfaction of not spending $275 labor and that it appears a lot of thought was put into how it operates.
