Sponsored by: Real Truck
Changing 4x4 switch
Old Oct 22, 2009 | 03:07 PM
Downriver Thunder's Avatar
Downriver Thunder
Changing 4x4 switch
Anyone know if you can remove just the little panel the switch is mounted to or if you have to remove the whole dash bezel? 05 F-250
Old Oct 22, 2009 | 06:49 PM
06silvercrew's Avatar
06silvercrew
No just the switch will pop out without removing entire bezel. Small pocket screw driver and she pops right out.
I have the one I removed from my truck when I converted it over to manual shift if you need one for cheap. PM me if interested.
Old Oct 22, 2009 | 11:00 PM
cole60's Avatar
cole60
is it a big job to conver to maual **** tcase?
Old Oct 23, 2009 | 10:56 AM
06silvercrew
Its not that bad if your mechanically handy and can do a little light fab work. But its not the most simple project.
Old Oct 23, 2009 | 12:22 PM
Downriver Thunder
That's the trick! Thank you. I just changed it. I had a new one in the tool box and my old one, the light burned out in it so I figured I'd change it. Popped right out but there was another wiring harness clipped into the back of the little panel too that I don't know what is for. Only thing there is the switch.
Old Oct 25, 2009 | 02:16 PM
06silvercrew
Pretty sure the other harness is for parking aid or power sliding rear window. When I went and got a plain panel to go in place of my switch when I did my conversion seems like those were couple of the options for that panel.
