Clock on Radio
Old Apr 27, 2006 | 07:53 AM
  #76
jrb1's Avatar
jrb1
Time all the time?
Is there any new news regarding the AM/FM radio with single CD & cassette and having time display automatically all the time?
It’s a real PITA the way it is! Almost a recall safety issue in my mind.
<O
My 2003 XLS is nearing the end of it warranty and I’d like to get this issues fixed; but the dealership seems confused!
<O
TIA,
Jim<O</O
Old Apr 27, 2006 | 09:44 AM
  #77
Outwest's Avatar
Outwest
I had the dealership replace mine, no cost to me as mentioned below..Keep pushing the issue. Its ridiculous to have the station show all the time...Good luck
Old Apr 27, 2006 | 10:25 AM
  #78
kw5413's Avatar
kw5413
<O
<O
TIA, Jim<O</O
Wow. Old thread.
Welcome to FTE and the 6.0 forum jrb1
If you haven't found it already, you might want to cruise over to our Tech Folder for some great 6.0 info.
https://www.ford-trucks.com/forums/showthread.php?t=303583
Please take a few moments to read our site guidelines as well.
https://www.ford-trucks.com/guidelines.html
Old Apr 27, 2006 | 10:39 AM
  #79
jrb1's Avatar
jrb1
Outwest: I'll give them a push!
kw5413: must of missed what you wanted me to see; didn't see any reference to my clock issue. Can you be more specific?
TIA,
Jim
Old Apr 27, 2006 | 10:55 AM
  #80
kw5413's Avatar
kw5413
I was just welcoming you to the site and showing you where the 6.0 Tech Folder is for a good read and future reference.
Old Apr 27, 2006 | 06:46 PM
  #81
Delawhere?'s Avatar
Delawhere?
[QUOTE=jrb1]Is there any new news regarding the AM/FM radio with single CD & cassette and having time display automatically all the time?
I had my radio in my 03 replaced at the dealer but it wasn't easy. I kept after them and with the info from the FTE web site in hand I went to them and showed them what other's had done. With that info they finally got a new radio and it worked just like the one in my 00 excursion. The clock stayed on instead of having to push a button to get it to come on every time the truck was started. Keep after the dealer and tell them to replace the radio!! Good luck!
Old Apr 27, 2006 | 06:52 PM
  #82
jrb1's Avatar
jrb1
Thanks for the encouragement!
Old Apr 27, 2006 | 07:06 PM
  #83
Delawhere?'s Avatar
Delawhere?
It took almost 13 months of complaining to the dealer every time I went in I'd ask if there was anything that could be done to fix the clock issue. But they kept saying no. It finally got fixed only after showing them the info that I had copied from the FTE forum, that others had had there radios changed out. This helped change there mindset and I had to be without a radio for about a week and a half while they got another radio. For some reason they had to take mine out first and order another one.
Old May 9, 2006 | 03:57 PM
  #84
jrb1's Avatar
jrb1
Thanks for the help and encouragement!
I now have a properly functioning clock !
Out of the dash, two days at the radio shop, then back in.
The info in this forum allowed me to dispel the "that's the way its supposed to work" attitude from the dealership.
I did find though a busted tab on the floor mat; looks more like the radio's plastic rather than the trim piece.
Any need to raise it as an issue with them?
TIA,
Jim
Old May 13, 2006 | 07:40 AM
  #85
Delawhere?'s Avatar
Delawhere?
TIA,
Jim
Jim, glad to see everything worked out OK! I don't know if the tab on the floor is anything to worry about though. It is amazing that something as simple as having the clock displayed instead of the frequency could be so exasperating to get fixed. Every radio station is required to broadcast its operating frequency every ten minutes by the FCC, but most like to tell you every 2-3 minutes or more. So having the frequency displayed continuously was a mistake on Ford's part, or the radio manufacturer. If I hadn't owned a truck with the same radio before the 03 I probably would have thought this was the way it had to be. But I had an 00 excursion that had this same radio and it displayed the clock full time, and I couldn't believe it when the 03's radio showed the frequency all the time. Anyway glad it worked out and welcome to FTE you will find the information to just about anything here!
dcsmith
2004 - 2008 F150
Aug 5, 2017 07:06 PM
bekko
Nov 1, 2013 02:22 AM
SnoopJonnyJon
3.0L V6
Oct 24, 2006 06:46 PM
mrladylover1469
Jul 30, 2004 03:57 PM
probablecause
Apr 22, 2004 06:30 PM
