02 sensor wire location
Old Apr 4, 2025 | 06:47 PM
  #46
F150 89's Avatar
F150 89
Figured I’d update everyone incase they have the same issue I ended up using the complete 1989 harness on the 1990 truck and pumps run good also with the start and stalling issue it turned out to be a bad alternator and ignition timing not being set completely I had it close but forgot to time it with the light but that only made it run better the stalling issue was due to a bad altornator killing the charged battery witch would allow it to run until the battery died u can check ur alternator by stating the truck and pulling off the red battery cable if the truck runs with the cable off it’s good if it don’t it’s bad
Blue460
Jan 21, 2025 04:31 PM
Rippin6Gears
Jan 17, 2016 10:53 AM
stangbanger
Sep 29, 2008 05:13 AM
fairlaniac
1983 - 2012 Ranger & B-Series
Sep 12, 2008 01:08 PM
