Spark plug porcelain breaking
Old Dec 15, 2024 | 09:56 AM
ULTRA_MAGNUS's Avatar
ULTRA_MAGNUS
a 1973 Ford F350 with a 390. Just rebuilt the motor 400 miles ago. The previous motor and this motor both break the porcelain on the spark plugs. They don’t come loose out of the hole but will crack and break the porcelain on the plugs. What would be causing this? I’ve always run auto light, spark plugs and never have had this issue in any other vehicle
Old Dec 15, 2024 | 10:10 AM
FuzzFace2's Avatar
FuzzFace2
It is the same plug(s) that are breaking?
Are you using a spark plug socket when installing them or a normal socket?
I have never seen them break on their own it is the socket that gets cocked and snaps it.
Dave ----
Old Dec 15, 2024 | 10:20 AM
beartracks's Avatar
beartracks
Are they cracking on the outside or cylinder side of the plug? Too tight? Too long?
Old Dec 15, 2024 | 10:22 AM
ULTRA_MAGNUS
Dave ----
five and six mostly but will be random sometimes. Using a spark plug socket.
Old Dec 15, 2024 | 10:24 AM
ULTRA_MAGNUS
it’s the porcelain on the boot side that breaks. They are spark plugs that the catalog says is for the motor. I torque them to spec.
Old Dec 15, 2024 | 12:20 PM
tbear853's Avatar
tbear853
Been changing spark plugs since 1970 or so .... and have yet to break one in anything ... except maybe the floor when one slid out of the box.
Old Dec 15, 2024 | 02:46 PM
Christmas's Avatar
Christmas
Same here. I would guess his spark plug socket is missing the rubber.
Old Dec 15, 2024 | 03:27 PM
ULTRA_MAGNUS
it’s not missing it’s rubber. They don’t break when I tighten them in. It’s after it’s ran a while and the porcelains will be broken.
Old Dec 15, 2024 | 03:30 PM
beartracks's Avatar
beartracks
Are you running hot?
Old Dec 15, 2024 | 03:33 PM
ULTRA_MAGNUS
not that I can tell. I have 180° thermostat in it and the temp gauge barely gets into the normal range. I don’t know the actual degrees that the engine is getting
Old Dec 15, 2024 | 04:01 PM
dlburch's Avatar
dlburch
do you have an infrared thermometer? I would run it hard then check the temps around the plugs/exhaust ports on 5 and 6 and compare to other cylinders that have never broken. Do you notice any pinging/detonation under acceleration?
Old Dec 15, 2024 | 04:35 PM
Christmas's Avatar
Christmas
What plugs are you using?
Old Dec 15, 2024 | 05:18 PM
ULTRA_MAGNUS
No pinging under acceleration. Timing is only at 15degres
autolites. Used them for years in everything I’ve owned this is the only engine I have a problem with them.
Old Dec 16, 2024 | 10:11 AM
FuzzFace2's Avatar
FuzzFace2
Like the others have said been changing plugs since the 70's too and never see them break when installed in a motor.
I might give Champ or NGK's a try to see what happens with them.
When you pull the broken ones out what do the hole side look like? Running lean / rich / just right or ?
What type of plug wires you running do they have sleaves to keep the wire from melting on a manifold / header?
Running manifolds or headers?
Dave ----
Old Dec 16, 2024 | 11:33 AM
tbear853's Avatar
tbear853
I don't recall the issue he was dealing with, but my old Sgt. & buddy "Leon" had a '80s F-250 to pull his big horse trailer, it had a 460 in it, and what ever the problem was .... it was fixed with new plug wires with insulated ceramic boots as I vaguely recall. I likely knew once, ... but whatever .... it was heat related, but I took it to be to protect the wires?
Maybe was to protect plug bodies from exhaust manifold heat.
msasteeler
6.2L V8
13
Nov 27, 2019 09:42 AM
TexasLonghorn75
2004 - 2008 F150
Nov 26, 2013 12:18 AM
1978 Ford
Modular V10 (6.8l)
Jan 5, 2009 12:55 PM
garysorenson
31
Jul 19, 2008 11:23 PM
