Options 8.7 inch ring gear
Old Nov 27, 2024 | 01:16 AM
Threefingers's Avatar
Threefingers
Trailering
So I just got a 69 ford f100 I was told it had a 9 inch ford rear end, not so. It is the dreaded 8.7" 3.50 ratio with open 28 spline axle. My question is, is it a matter of just finding a 9" rear end axle to swap that possibly came out of a ford truck? What are the questions I need to be asking and looking for. I am not well versed in this area as you can tell. If you can dumb it down for me that would be appreciated.
Old Nov 27, 2024 | 01:19 AM
85e150's Avatar
85e150
Is it leaking, making noise or is 3.50 not to your liking?
if it's tight, quiet and the right RPM/mph combination then run it.
Swerving suggestion.......
Old Nov 27, 2024 | 01:30 AM
Threefingers
Trailering
Well, my plan which is just starting at the dreamer stage is to restore the truck and beef up the motor in a rebuild. Mild cam, new heads, manifold, and carb upgrades. I am looking to boost a little more hp. In reading about the rear end everyone seems to have the same consensus and that is scrap it because you can't find parts and its not buildable. Right now it works
Old Nov 27, 2024 | 01:34 AM
85e150's Avatar
85e150
Run it, do your engine and see where that and the transmission land, then get the right ratio with the new axle.
Old Nov 27, 2024 | 04:44 AM
Crop Duster's Avatar
Crop Duster
There isn't anything wrong with the 8-3/4-inch ring gear (9-inch) rears. The weak point is the axles not the center section. That said those rears are generally considered good for up to 450 HP. Adding traction loc is as easy as swapping the center or having yours rebuilt and there are aftermarket 28 spline axles that are bullet proof. Unless you are drag racing with Big sticky tires that rear is plenty strong.
Old Nov 27, 2024 | 10:29 AM
Threefingers
Trailering
. Sounds like good advice, its been holding up for 55 years so I'll just go with it for now.
Old Nov 27, 2024 | 10:40 AM
FuzzFace2's Avatar
FuzzFace2
I will 2nd what they both said for street with a little built up motor and maybe a pass or 2 at the strip you will be good.
Dave ----
fifty-two_f1
19
Jul 10, 2017 03:04 PM
tardster
Dec 31, 2010 09:25 AM
FmissingtheORD
19
Feb 11, 2010 02:36 PM
pipman76
Sep 5, 2009 06:37 AM
1956f100
Oct 22, 2002 08:46 AM
