Oil & Lubrication
Eaton axle lube question
Old Nov 26, 2024 | 02:44 PM
wschneider's Avatar
wschneider
Trailering
I'm seeing varying opinions about Eaton 2 speed rear end lubrication. I have a 1980 Ford LN800 with a single axle 2-speed electric rearend. I see in the manual that it has a couple of clutches within the assembly. Does this rearend need a friction additive such as sta-lube added? Also, do I need to find 80w-90 GL4 for it? Thanks for any advice.
Old Nov 26, 2024 | 03:06 PM
85e150's Avatar
85e150
https://www.doverbrakeinc.com/downlo...02%20SPEED.pdf
Short version: MIL-L-2105D
This stuff meets the spec:
https://www.valvolineglobal.com/en-n...etic-gear-oil/
Old Nov 26, 2024 | 03:41 PM
wschneider's Avatar
wschneider
Trailering
Thank you!!
BigBlueRanger1977
May 22, 2024 01:26 PM
JoePa2
Oct 6, 2023 08:46 PM
Ranger Bob
2004 - 2008 F150
50
Aug 3, 2014 07:34 PM
dazedandconfused
Large Truck
13
Apr 12, 2010 05:21 PM
