Which Moose Pump?
Old Mar 7, 2025 | 09:43 AM
eatont9999's Avatar
eatont9999
Originally Posted by Olds64
x2
I'd think the ol' ATF trick in the fuel filter would be something you do to an IP with 100k+ miles on it, like my 6.9l. Didn't you also mention you got injectors from Moose?
I did not get Moose injectors. I did buy new (not reman) G code injectors a few years ago. They only have maybe 2000 miles on them. I pop tested them as well and at that time, they were all within spec.
Old Mar 7, 2025 | 01:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
i am wondering if the suggestion to run conditioner to free up the metering valve is maybe it is an off the shelf pump that was built and tested a while ago, and the fuel residue in the pump may have gummed and stuck the valve.
Old Mar 7, 2025 | 06:05 PM
eatont9999's Avatar
eatont9999
I had that same thought as well. I'm not sure what their inventory looks like but it sounded like they are very interested in acquiring cores, so I assumed they don't have a lot on the shelf but that's just a guess.
Old Mar 8, 2025 | 04:03 AM
Olds64's Avatar
Olds64
When you bought the IP from Moose did you send in a core?
I bought new injectors for my IDI years ago from the auto parts store. They seem to work ok, but I recently installed a return line kit and one of the injectors was all carbon fouled. I guess I should build or get a pop tester because I have plenty of cores and I've read they aren't difficult to rebuild.
Old Mar 8, 2025 | 06:31 AM
tjc transport
i ain't rite
i think the hardest part of the DIY injector rebuild is finding parts. 25 years ago they were all over the place. now the newest of these engines is 376 years old and parts supplies are drying up.
Old Mar 8, 2025 | 01:24 PM
eatont9999's Avatar
eatont9999
I sent in the IP I bought rebuilt and later I also sent them a core that I had sitting in my shop. Rebuilding the injectors isn't hard but you need shims, good springs and new injector nozzles. I have yet to find a source for the correct nozzles, though.
Old Mar 9, 2025 | 04:38 PM
eatont9999's Avatar
eatont9999
Well, you guys were on to something with the ATF in the fuel filter trick. I'm happy to report that the stalling issue has gone away!
I decided to change the fuel filter since it did not look good. the truck has mostly been sitting up for a few years. I filled a new filter with 50/50 ATF and Howe's, ran her for a minute or two and let it sit about half a day. I actuated the shutoff and cold advance solenoids a few dozen times as well. I decided to drain the tanks by pulling out the fuel through the bleed port on the filter housing. I'm running off the rear tank with fresh fuel until I drop the front one and clean it.
twfish
6.7L Power Stroke Diesel
Sep 5, 2012 09:30 PM
oldblue89
Mar 9, 2011 02:50 PM
rupejosh
Feb 18, 2010 05:51 PM
94F250TD
Jul 24, 2007 07:34 PM
460429_freak
Jun 26, 2003 09:48 AM
