Injection pump bolts
Old Jun 12, 2004 | 10:17 AM
Jeff A's Avatar
Jeff A
I am new to this website but am amazed at the information available! It is great that all are willing to share their experience! Maybe someone can help with the following,
I am preparing to replace the IP on my 93 7.3 n/a. Will a regular open end 9/16" wrench work to remove the bolts or do you need the special ford tool or equal. Please help. Thanks
Old Jun 12, 2004 | 04:42 PM
ditch witch's Avatar
ditch witch
Jeff, I have an older truck but the pumps are physically the same. I use an assortment of 9/16" wrenches. Long, short, wide, bent---anything to reach. You'll need a 5/16", 12 point to get the 3 bolts that are under the front cover plate under the oil fill cover. I didn't have one in my assortment of wrenches and when I went to the auto parts stores the did not have them either. Ended up at a hardware store, and they had a 3/8" drive.
You'll need a 5/8" to remove the fuel lines.
Old Jun 13, 2004 | 09:12 PM
dave200's Avatar
dave200
IP wrench...
Take 9/16" box end and grind it down so it is thinner than stock. Across the box end. You have to experiment. stop grinding when it will fit onto all 3 nuts. Use that to crack them, then an open end works fine.
when finished, tape your 5/16" 12pt socket to your "special" IP wrench and put them where you can REMEMBER. hopefully, you'll only get them out to loan to somebody.
Dave
Old Mar 9, 2025 | 09:29 PM
ccravens's Avatar
ccravens
6th Gear
Does anyone know the part number for these bolts or the specs on them? I need to replace them but have no information. Pitch, grade, length?
ynot321AB1
May 18, 2021 01:06 PM
Dixon1948
13
Jan 26, 2020 04:10 PM
YardPig
15
Aug 16, 2013 12:16 PM
gemmBronco
1978 - 1996 Big Bronco
May 27, 2006 08:28 PM
jcs1966
Oct 28, 2004 05:06 PM
