Ford 390fe smoke
Old Nov 9, 2024 | 06:10 PM
Yankee farmer's Avatar
Yankee farmer
Ford 390fe smoke
Hi guys new here. I'm looking at a 74 f350 with a 390 in it. The truck is in decent shape, (it will need some body work). The engine fires up nice and seams to run ok, but it is smoking pritty bad. The question is, can running to rich/ sitting cause these engines to smoke? The smoke doesn't smell like burnt oil it smells like rich cruddy gas. The truck has been siting a wile. It has 120 thousand miles, so I wouldn't exspect it to be a oil burner. Any advise would be helpfull.
Old Nov 9, 2024 | 06:56 PM
85e150's Avatar
85e150
Welcome to FTE!
Black smoke is rich.
Blue smoke is oil.
You may have busted up valve seals, and OEM feature on many older Fords. A nuisance to replace, but not terribly costly.
Since it's a '74 it probably has D2TE heads that originally had hardened valve seats, so if it's running on all cylinders, your heads are probably "good", even if the seals are crap.
A carb rebuild will cost you $50 or so, and will clean up the black smoke.
Does it have the OEM fuel pump on the driver side of the engine?
Or an added on electric fuel pump?
What carb is on it?
Beware, all 360s become 390s on sale day, so check that VIN. 4th character is Y for the 360 and H for the 390.
Old Nov 9, 2024 | 07:44 PM
Yankee farmer
Thanks for the info! It has blew smoke, so probbly is burning oil. The weard thing is it don't smell like oil smoke. The guy says he did all new valve seats a few years ago. What do you think is cause the smoke? Rings or valve guides?
Old Nov 9, 2024 | 08:06 PM
85e150's Avatar
85e150
Valve seats would be a "valve job" in the old days parlance.
Valve seals is what goes to pot in the Ford engines. They are neoprene umbrella seals. A few heat/cool cycles and they start to get hard, and a few thousand more they start to crack. They eventually fall apart and help clog the oil drain back holes creating a clear path for oil to run down the valve stem, and in some cases creating a nice pool of oil at the ready inside the valve cover.
Of course it could be rings too.
The FE is not a cheap engine to work on. You may have to search out someone to work on it if need be--especially if you do a rebuild.
The truck sounds like a bit of a project in the first place. Body work and engine work? Too much for some, pure heaven for others.
What transmission?
How are the tires and brakes?
Old Nov 9, 2024 | 08:10 PM
FuzzFace2's Avatar
FuzzFace2
I wounder if because it has not been used much that the rings might be stuck in the grooves?
Sometimes you can soak them still in the block with ATF and then work the motor hard and they may free up.
My .02
Dave ----
Old Nov 9, 2024 | 08:24 PM
Yankee farmer
Alright, I think I'm calling it on this truck. I don't want a truck that needs a engine rebuld first thing. I'm have no problem redulding engines. I just don't need a huge project rate now. I thought the smoke was fishy. I wonder if it is a head gaskit. The truck is cheep, but it needs a lot of work to make it right. The cab ant terrable. The floor pans and cab mounts are in great shape, but the cab is rotted out all around the top of the windsheld. Thanks guys for the help.
Old Nov 9, 2024 | 08:28 PM
Yankee farmer
Ps the tires are good. It needs a front brake line. It has a 4 speed in it. Clutch is great. It also needs a pto pump. I think I would buy it if the engine didn't smoke,
Old Nov 9, 2024 | 08:32 PM
85e150's Avatar
85e150
I would be more put off by rust above the windshield than engine work.
Engines wear out--it's a given.
Rust--now rust gets everywhere it can.
Wouldn't be a head gasket. That would give you water in the oil, oil in the water, one or two cylinders missing, steam out the exhaust etc.
There is no pressurized oil going through the head gasket. Only drainback.
One other FE oil burner possibility is a bad intake manifold gasket that allows oil to be sucked into the intake. Usually you get a miss or some other "runs bad" problem with that.
Old Nov 9, 2024 | 08:41 PM
52 Merc's Avatar
52 Merc
Agreed. If the cab is rotted out and it needs an engine, no bueno. Time to move on.
Old Nov 9, 2024 | 08:50 PM
Yankee farmer
Yep I'll be looking for another truck. I don't mind the body work, the truck just needs a lot of differend things. On the east cost rust free trucks DO NOT exsist. I just think its interesting that the smoke didn't smell like burning oil.
Old Nov 10, 2024 | 12:54 AM
Hypoid's Avatar
Hypoid
Its normal for one to smoke when you take it out of storage. It will need some run time to get the rings sealing again.
Old Nov 10, 2024 | 05:53 AM
FuzzFace2's Avatar
FuzzFace2
The roof rust would be the BIG turn off for me.
I came from New England so rust is not that big a deal most places but after seeing some of the roof gone I would move on.
Dave ----
wdenning81
Nov 4, 2010 12:56 PM
beersy50
Nov 15, 2009 07:32 PM
tylstruck
Apr 27, 2008 07:37 PM
jpjshy13
Aug 3, 2004 08:07 PM
