White smoke Gas smell
I have seen some forms that are close to my problem but not really the same so here it goes....
I have a 2000 F250 5.4L, on cold days it will start right up but sometimes will die once, But the biggest issue is it smells like it is running really rich, there is some white smoke out the exhaust too, but runs fine, there is no check engine light on...... weird
thank you for your help in advance.....
No, I have seen head gaskets that seal up to a degree when the engine heats up and expands.
Other causes of massive oil burning (mechanical damage, rings, valve seals) usually will not seal when the engine heats up. Minor valve or ring issues will tend to seal when hot but if it is bad then probably not.
I would start with a compression test and a leak down test of the engine.
Daniel P
03-29-2017 06:30 PM
ThatOneGuyFromNarnia
12-16-2016 02:01 PM
jwmayfield
07-18-2013 08:04 PM
