white smoke?
Old Nov 14, 2009 | 04:18 PM
beersy50's Avatar
beersy50
white smoke?
A friend of mine as 89 f-350 4x4 automatic w/ 7.3. He just bought it. The previous owner said he was getting h2o in the oil so, we rebuilt the oil cooler on it. We only ran it for aproximtly 15 min. and its blowing white smoke alot! The smoke dosen't smell like antifreeze and there is none in the oil and vise versa. Any thoughts?
Old Nov 14, 2009 | 09:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Does the white smoke smell like fuel?
Leaking injectors can cause white smoke as well, unburned fuel.
The smell the smoke test is the only way to tell the difference.
Old Nov 15, 2009 | 03:23 AM
rupejosh's Avatar
rupejosh
my bet is injectors as well.does it run rough when it starts to smoke? im betting if you rev it a little while its smoking it will knock a little as well.does it go away if you leave it run after it starts to smoke?i have an injector that acts up here and there and does the same thing.
Old Nov 15, 2009 | 05:51 AM
rckslash2010's Avatar
rckslash2010
Mine runs rough like that for about 15 seconds first thing in the morning, and blows white smoke. I was working out of town about 3 months ago, and when I started my truck up in the morning, it ran rough and blew white smoke for about 10 minutes. It filled the whole motel parking lot full of smoke and looked like something was on fire, I'm surprised nobody complained, It only happened that one time like that.
Old Nov 15, 2009 | 04:23 PM
beersy50's Avatar
beersy50
The truck dosen't seem to run rough when it smokes, it appears to smoke less when reved up. Also the smoke just smells like Diesel exhaust. It clearly isn't sweet smelling like anti-freeze. Also I do know that a couple injectors (3, I think) are leaking. I can see it seeping out of them when the truck is running. Any other thoughts before I tell him to start replacing injectors? Also What injectors so you guys suggest?
Old Nov 15, 2009 | 06:49 PM
Dave Sponaugle
If you see the fuel leaking outside the injectors, air in the injection lines could be causing more fuel to be injected is a couple cylinders, producing white smoke.
The usual leaking injector problem is when the injector is leaking fuel into the cylinder when the injector should be closed.
Again causing white smoke.
And in both of those examples, the white smoke usually has a very strong fuel smell to it.
Old Nov 15, 2009 | 07:32 PM
beersy50's Avatar
beersy50
That seems to be the problem then, What brand injector to you suggest? Bye the way thanks for the help.
Bruteskeg
6.4L Power Stroke Diesel
Feb 6, 2014 05:44 PM
cheddar89
15
May 17, 2012 06:15 PM
linus72
Apr 16, 2012 07:40 AM
rkbutz55
Jan 14, 2011 01:13 AM
Unrealo4
Dec 28, 2010 10:37 PM
