Repeat Injector O Ring Failure Please Help!
Old Nov 13, 2024 | 07:57 AM
TooManyToys.'s Avatar
TooManyToys.
What is going on with the FTE software. This is the second day this has happened. There are no problems doing this over on the ORG.
Old Nov 13, 2024 | 08:03 AM
TooManyToys.
Let's see if a PDF attaches...
File Type: pdf
Old Nov 13, 2024 | 09:10 AM
Hartwig's Avatar
Hartwig
Originally Posted by fosp
is there a big issue with installing them in the truck? I have done it on 7.3s with no issue but it would just save a lot of time in my end since it’s with the cab on
The sleeves sit very tightly in the head . I think with cyl.#5,7,6 or 8 this might be a difficult job. I don't do it with the head installed, regardless of the cylinder.
Old Nov 13, 2024 | 12:25 PM
Hartwig's Avatar
Hartwig
I can't find any pictures of the tool to replace the injector sleeve in the head...somewhere on my computer are these. I also bought the tool from Accurate Diesel.
These stainless steel sleeves normally last the life of the engine. In my experience, it's always assembly failure that leads to problems.
Firstly, the hole for the injector hold down clamp bolt is not blown out with compressed air. As a result, the injector is not pressed onto the seal seat with the necessary force and the injector “hammers” the sleeve.
Secondly, the sleeve is not cleaned when the injector is changed. It is difficult to get to the sealing surface. I have designed a tool for this which you can make yourself with a 3D printer. You wrap a clean cloth around it and you can easily reach the sealing surface. If you have access to a printer, I can email you the stl file.
Old Nov 13, 2024 | 12:37 PM
TooManyToys.
Milasevich
Dec 28, 2021 08:32 PM
itellyouwhat
Sep 19, 2021 11:35 AM
NavyNate
Jul 30, 2021 01:39 PM
dmmccarter
Jul 15, 2020 10:38 AM
Fordenthusiasts
23
Sep 6, 2015 11:23 PM
