Strange Debris Found Under Injector
Old Jul 28, 2021 | 10:03 PM
NavyNate's Avatar
NavyNate
Hello everyone!
I am in the process of replacing my injectors, and I found something interesting when I pulled #8. There were at least two small pieces of debris under the injector, in the cup. They are almost like a red plastic-like material. I managed to fish two out, but lost the smaller piece before I could get a picture of it. Here is the larger piece. Bottle cap for reference.
Think this is something to worry about? I got everything all cleaned up and to my eye, the cups looks OK.
Old Jul 28, 2021 | 11:44 PM
Wes444's Avatar
Wes444
That looks like the broken tip of an IPR?
Machining marks consistent with being turned on a lathe along it's diameter
Old Jul 29, 2021 | 03:24 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
But honestly no idea. Some bit of plastic, and if the the lost part went down into the cylinder I'd say roll the engine over by hand a couple times. It will be broken up to harmless bits that will burn off.
Old Jul 29, 2021 | 06:09 AM
Walleye Hunter's Avatar
Walleye Hunter
Surely, that's a typo?
How well did it run with that under there? Is it possible it was hanging around and dropped in after you pulled the injector out?
Old Jul 29, 2021 | 05:34 PM
Bonanza35's Avatar
Bonanza35
What Mark Said!
Old Jul 29, 2021 | 07:25 PM
Listor's Avatar
Listor
Originally Posted by Bonanza35
What Mark Said!
I too doubt it was under the injector, some debris from above most likely
But stranger things have happened
Old Jul 29, 2021 | 09:23 PM
udsuth78's Avatar
udsuth78
I'd bet something similar to this.
Ended up in this vicinity.
#8 hole right? Somebody probably fell for the long lead injector fix, and either a diy'r needs his or her tool set taken away or a tech had a hell of a hangover.
Old Jul 29, 2021 | 10:23 PM
NavyNate's Avatar
NavyNate
It's certainly possible that it fell into the cup after I removed the injector. I would be surprised if that was the case though, I was being as careful as I could.
It was a LL injector from hole number 8. My truck had at least two previous owners before me, so no idea what all has been done to it. That would be pretty hilarious if it was some kind of plastic cover that got pushed into the cylinder! Lol
I'm going to go with what aawlberninf350 said and hope that whatever it is is long gone. New injectors on the way from riff raff right now.
Old Jul 30, 2021 | 01:25 PM
Bonanza35's Avatar
Bonanza35
This idea could be it to. Never even thought about that. Good suggestion. Never know what people before you did.
Old Jul 30, 2021 | 01:39 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Interesting! @udsuth78 may be on to something!
uglypitbull
Sep 30, 2020 09:10 PM
Merlyn James
Apr 3, 2020 06:20 AM
Wannaspeed
Sep 10, 2017 04:31 AM
RacinNdrummin
35
Nov 20, 2012 12:59 AM
CAPTAIN DIESEL
Sep 30, 2011 05:57 PM
