Engine alignment tips?
Old Nov 8, 2024 | 06:36 AM
BobbyFord's Avatar
BobbyFord
Originally Posted by gwp36530
Transmission is a 3 speed toploader. 302 has front sump oil pan so mounts are the type which span from block to frame rail. See pic. I know the trans tunnel is offset but these mount only allow center position. I read that this is OK so long as driveline angle is phased correctly. Downloaded the really helpful tremec angle finder app and thinking I'll go 2.5 - 3 degrees on pinion and trans spline. There obviously will be some horizontal angle due to offset pinion but I read that isn't a problem. Looking like the intake/carb
is gonna be pretty close to level. My trans support has been modified by previous owner and looks like I will need a around 2-3" spacer between support and mounting foot of trans tailpiece. Any ideas of what i should use for spacer? Does this all sound ok? 1st time down this road for me. Thank you for advice!
Why do you have the frame bracket all the way at the top of the frame rail? The positioning of that bracket in the frame rail can be used to adjust driveline angle of the engine/trans.
For my combo, the frame brackets worked best mounted toward the center of the frame rail.
Old Nov 8, 2024 | 03:36 PM
gwp36530's Avatar
gwp36530
Bobbyford...
Very interesting set up you have there and much beefier. Very impressive workmanship and definitely an option for me. Thanks for posting.
Old Nov 8, 2024 | 03:47 PM
gwp36530's Avatar
gwp36530
The reason for mounting bracket on upper end of rail is because clutch z bar lines up at proper elevation this way. That's another concern.... exhaust, clutch linkage and shifter linkage is all crammed up tight but i think it will work out ok. Another reason to mount it this way is to have the option of drilling horizontal top rail and having two more bolts to secure bracket. Think that is a good idea?
Old Nov 8, 2024 | 05:10 PM
BobbyFord's Avatar
BobbyFord
Extra bolts isn't a bad idea. I wonder if there is a hydraulic master and slave cylinder available for your setup that could eliminate the mechanical clutch linkage...
Old Nov 9, 2024 | 07:40 AM
gwp36530's Avatar
gwp36530
Well there is an interesting idea. Found a utube which describes this process on a 63. Surprisingly... they even make a hydraulic clutch kit for a 63. Never realized this was an option but very comforting in case I run out of room down there. Thanks much
toymobile
Ford Truck Parts for Sale
Oct 2, 2016 03:24 PM
73FOMO
Dec 13, 2006 08:41 AM
rmalottwtes30
Nov 23, 2006 07:45 PM
bollyfoxin
Oct 18, 2006 06:26 PM
radramrod2
Feb 1, 2005 12:29 PM
