Finally got it done. Thanks to everybody who chimed in, especially @Dirthawg2.0 for those torque specs. Probably won't ever do that job again Total PITA. But I'm glad it's done now. No more horrible noises on cold winter mornings. At 14:28 in the video I noticed something interesting about the tensioner. It appears to me that the Gates brand and Motorcraft brand are the same part.
I was going to buy a serpentine belt tool kit and try this at home but now after seeing this, will probably get my buddy's shop to put it in...
That's the kit I have that I bought from Rock Auto. I meant to do it last year in the warm weather....
I'm going to save the original pullies as I have a set of new bearings for them for the next time for belt replacement....
Thanks for posting.
I wonder if the salt is whats causing these pullies to go bad. I still have the factory original on mine. Now that I say that, they will probably go out today.
If the fan shroud and the throttle body were removed, this would be a 15 minute job. But, I didn't know how long it would take to remove the fan shroud and throttle body. It's a real shame. A textbook example of a 15 minute job that takes hours simply because of poor access.
For what it's worth, at 100k miles exactly my original belt looks pretty good. I kept it as a spare in my barn (can't see myself spending 3 hours on the side of a highway doing this, so I'd just tow it home if I had to). No sense in throwing it away.
Mine are still good I'd assume. I just bought the kit to be proactive and when I talked to my buddy with the shop where my truck goes, says it's a good idea to replace those pullies and tensioner with the belt. I'll post up pics of my belt and pullies when the job is done.
Hopefully not, Troy... but I hear ya.
That was going to my question to you, about the fan shroud, and how hard it was, if you even checked out how to pull it... I already know how to pull the "throttle body" from my DPK install.
I recall watching a video some time ago, regarding replacing the vacuum pump (or its gasket/o-ring). In that video the guy removed just about everything to get access, and detailed what was required to remove the fan and surrounding shroud.
I'll see if I can locate it, and post the link if I find it. If I recall correctly, it was a bit messy and more complicated that it should've been.
I recall watching a video some time ago, regarding replacing the vacuum pump (or its gasket/o-ring). In that video the guy removed just about everything to get access, and detailed what was required to remove the fan shroud.
Well, can't find that video. But, did come across one that might be helpful. Starting around the 2:00 mark, shows how to disconnect the harness from the fan, and then the fan itself. Then, removing the serpentine belt. He sure makes it look easy, lol.
Crap, it's not available? I viewed it while performing a search. Unless, you have to have a YuuuTuuuube account... The link is this (remove the ZZZ in the link): https://youZZZtu.be/4UdgFBRHXyQ
