Squeak after coolant flush
Old Nov 29, 2013 | 10:50 AM
Jesser02EX's Avatar
Jesser02EX
Yesterday I completed my coolant flush. After completion, I have a squeak around the serpentine belt. Does anybody have an idea of where I should look? While doing the flush, The thermostat housing leaked. It was a very wet job to do. I'm sure through the process water washed off some nice grease that had Lubed to stuff up.
The squeak can be really annoying when the truck is just idling. The belt looks good and I don't feel any play but I still want to be sure.
Can I squirt a little WD-40 on the bearings?
Old Nov 29, 2013 | 10:52 AM
Pikachu's Avatar
Pikachu
Probably got some coolant on the belt. Mine squeaks even when it's not actually wet, but the humidity is high.
Old Nov 29, 2013 | 10:59 AM
Jesser02EX's Avatar
Jesser02EX
Coolant got all over the place. Should I just wash it off with a lot of water and watch it? Is there any type of belt conditioner I can buy?
Old Nov 29, 2013 | 11:07 AM
Pikachu's Avatar
Pikachu
Yeah, hose the belt off well. If it doesn't get better after it's good and dry, you can try some belt dressing on it, but I've not had good luck with it. I used it a couple times when my belt was on it's way out, but the squeaking always came back in a day or two. Replacing the belt was the only real solution in that case. It sure is an annoying noise, isn't it?
Old Nov 29, 2013 | 04:25 PM
Jesser02EX's Avatar
Jesser02EX
I have an extra belt, guess I could change it out...
Old Nov 29, 2013 | 04:41 PM
Bonanza35's Avatar
Bonanza35
Wash it good and use some comet on the belt that will keep it from slipping.
Old Nov 29, 2013 | 05:06 PM
t.scottNDU's Avatar
t.scottNDU
I'm having the same thing happen right now, with a brand new tensioner and idler pulley. It's a very subtle squeak that you can barely hear unless your head is near the grille on the drivers side, but annoying nonetheless.
I figure the belt is on its way out, I have a Gates HD waiting.
I read in a thread recently that someone used a sprinkle of baby powder and the squeak was cured.
Old Nov 29, 2013 | 06:28 PM
Jesser02EX's Avatar
Jesser02EX
I don't know if it's slipping. It was all the time, but after messing with it, it's just when I step on the pedal. Aside from using a breaker bar on the tensioner, is it hard to get a new belt on? I have the wrap around radiator hose so that won't be an issue.
Old Nov 29, 2013 | 06:36 PM
Pikachu's Avatar
Pikachu
It isn't difficult at all. Might be a good idea to make sure the belt routing diagram is still under the hood or take a couple pictures before you remove the old one, though.
Ron94150
Oct 5, 2015 11:28 AM
bakerbuilttracks
28
Nov 21, 2012 01:59 PM
stoney720
Apr 18, 2009 09:44 AM
savage250
May 2, 2007 10:32 AM
Mark53207
Jun 1, 2004 04:48 AM
