Oil Filter Adapter
Old Oct 16, 2024 | 04:21 PM
bryce12's Avatar
bryce12
8th Gear
Oil Filter Adapter
I recently replaced the oil filter adapter on my 6.7 Powerstroke due to it being corroded. After replacing it I have noticed an oil leak clearly coming from the new adapter I installed. I torqued all of the bolts to 89 in lbs so I am not sure why it is leaking. I reused the same gasket because it looked like it was in good shape. Any thoughts?
Old Oct 16, 2024 | 05:27 PM
speakerfritz's Avatar
speakerfritz
Must not be clean surfaces
nothing wrong with removing, cleaning all surfaces , gasket maker on one side of gasket, let sit for a minute , reinstall, tourque all bolts in increments ….start at a low torque , round robin them up in steps to final torque.
Old Oct 16, 2024 | 05:47 PM
bryce12's Avatar
bryce12
8th Gear
Cleaning
What do you recommend I use to clean the surface?
The mating surface was looking rough before I put the new housing on. I was just worried I would scratch up the surface if I went to aggressive with the cleaning. I’ll include a picture of the surface before I cleaned it.
Old Oct 16, 2024 | 06:22 PM
speakerfritz
This and use a plastic scraper
you need a new gasket
Old Oct 16, 2024 | 06:27 PM
bryce12's Avatar
bryce12
8th Gear
The material on the surface is not gasket material. I believe it might be some more corrosion from salt. The gasket is rubber and sits inside of the oil filter adapter. The gasket looks fine to me. But I could order a new one from ford. I will try a plastic scraper and maybe a scotch bright pad.
Old Oct 16, 2024 | 08:19 PM
FishOnOne's Avatar
FishOnOne
If the mating surfaces are pitted you could apply a very thin coating of automotive silicone on both sides of the gasket. But this would be the last resort if you can't solve the leak issue.
Old Oct 17, 2024 | 05:51 AM
bryce12's Avatar
bryce12
8th Gear
I will try to clean it up some more. Is it not safe to use automotive sealant or gasket maker on the outside of the actual gasket?
Old Oct 17, 2024 | 07:05 AM
rufushusky's Avatar
rufushusky
^^^ This....
Old Oct 17, 2024 | 07:36 AM
JoeUser's Avatar
JoeUser
As previously mentioned, scrape all surfaces, clean with alcohol, and apply a new gasket.
Myself, I'd probably coat both sides of the gasket with copper coat, just as a failsafe against leakage. K&W used to make it but were bought out by CRC. Permatex makes similar, as well.
https://www.crcindustries.com/copper-coat-aerosol/
https://www.permatex.com/products/ga...sealant-12-oz/
Old Oct 17, 2024 | 07:40 PM
bryce12's Avatar
bryce12
8th Gear
The gasket is a rubber ring you don’t apply it to the engine block it sits directly in the oil filter adapter. The gasket I have looks fine but I will order a new one through ford. The marks you are seeing is not gasket residue.
Old Oct 17, 2024 | 07:51 PM
Overkill2's Avatar
Overkill2
The gasket may look fine but obviously it's not if the adapter is leaking once torqued to spec... it's probably a little hard or shrunk down from being squeezed in there and from all the heat cycles. It's cheap insurance and should fix the issue...
https://shop.fullforcediesel.com/for...adapter-gasket
Adapter Gasket For 2011-2019 6.7L Powerstroke - Picture 1 of 1
c mobley
2015 - 2020 F150
15
Jan 22, 2024 01:24 PM
cheddar89
Feb 23, 2012 12:34 PM
unhcp
Sep 28, 2011 11:57 AM
mblanken881
Jan 10, 2009 07:58 PM
alans77crew
May 3, 2006 06:13 PM
