Oil leak!!
Old Feb 23, 2012 | 02:13 AM
cheddar89's Avatar
cheddar89
Oil leak!!
Finally got a carb put on it and changed the oil and when i started it oil ran out where the filter goes there is a big round piece that bolts on before the filter screws in does anyone know where i can get a replacement seal for it??
Old Feb 23, 2012 | 02:49 AM
fordpt's Avatar
fordpt
Thumbs up
What are you working on?
Old Feb 23, 2012 | 03:16 AM
critterf1's Avatar
critterf1
That might help. Check the old oil filter for a gasket, I'll bet it's still on the engine.
Old Feb 23, 2012 | 09:48 AM
cheddar89's Avatar
cheddar89
It is a 223 the filter isnt leaking there use to be a bigger filter and the adapter is leaking
Old Feb 23, 2012 | 12:25 PM
wtx66f100's Avatar
wtx66f100
Sounds like you may have the wrong size filter and it is not sealing. You might want to check with your local parts store and make sure which filter you need to use or if you still have your old filter write down the part number and manufacturer and get the same one or they could cross reference it for you to use another brand of filter.
Old Feb 23, 2012 | 12:34 PM
cheddar89's Avatar
cheddar89
Its not the filter its right above the filter theres a round adapter for a diffrent style filter ill see if i can post a pic
PlainJaneTruck
18
Jan 27, 2021 03:26 PM
unhcp
Sep 28, 2011 11:57 AM
mblanken881
Jan 10, 2009 07:58 PM
alstieg
20
Oct 27, 2008 04:32 PM
lilpig88
Jun 22, 2003 08:13 PM
