Sponsored by: Real Truck
Oil leak
Old Sep 23, 2011 | 12:12 PM
unhcp's Avatar
unhcp
Oil leak
Changed my oil last night and now I have a oil leak, it is coming from the area around the filter. I tried another filter and it is still leaking. I did some research and I think it is the oil filter cooling adapter or oil filter adapter?
Any ideas?
Old Sep 23, 2011 | 12:18 PM
Pili's Avatar
Pili
Could be the adapter, by any chance did you check to see if the rubber ring from the old filter is still on?
Old Sep 23, 2011 | 12:53 PM
unhcp's Avatar
unhcp
still on the old filter
Old Sep 23, 2011 | 01:48 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Maybe from the previous one and last time you got LUCKY?
Old Sep 23, 2011 | 02:05 PM
unhcp's Avatar
unhcp
the housing around the filter looks corroded, so that is why i think it is the oil filter cooler adapter
Old Sep 23, 2011 | 03:46 PM
unhcp's Avatar
unhcp
ford wants 170 bucks, is this the same thing:
02 2002 Ford F-350 Super Duty Oil Cooler Adapter - Engine Mechanical - Flexalite | Drivewire.com
Old Sep 24, 2011 | 06:54 PM
onebadv2's Avatar
onebadv2
I don't think this is what you need. I have an '03 with the 5.4 and developed the same descriped leak. Mine was the oil filter mounting adapter that developed a pin hole due to the corrosion. A friend found it when we put air pressure on it. Thank God I saw a little oil on the drive when I pulled out for a 200 mile trip and checked it. I would be looking for a new engine if I hadn't.
Old Sep 25, 2011 | 08:53 AM
unhcp's Avatar
unhcp
Ok so what is that? What is the part number?
Old Sep 26, 2011 | 04:54 PM
unhcp's Avatar
unhcp
YC3Z6881DA Adaptor Oil Filter 01 02 03 04 F250SD | eBay
is this what i need?
Old Sep 27, 2011 | 08:40 PM
onebadv2's Avatar
onebadv2
I think I would crawl underneath and wipe everything down clean and then try to see where the leak is coming from. You might have to dissassemble and put air on your adapter to make sure it is the problem. Without some investigation, your just guessing and hoping.
Old Sep 28, 2011 | 11:57 AM
unhcp's Avatar
unhcp
thanks i will check it out
PlainJaneTruck
18
Jan 27, 2021 03:26 PM
Rob89
6.2L V8
17
Nov 3, 2019 03:05 PM
mblanken881
Jan 10, 2009 07:58 PM
alstieg
20
Oct 27, 2008 04:32 PM
