Hit the button. Done. Now DO NOT do this with the truck under heavy load. So either at a stop light or when coasting would be a better process.
Why do you say this? It is not necessary, or better, to be at a stop light or coasting when engaging tow/haul or to avoid engaging it when under heavy load. Tow/haul changes the transmission programming. There is no mechanical aspect that suggests engaging it under load will cause damage.
I could see it potentially getting confused if you were under acceleration and hit the button AS it was shifting, and possibly causing an undesirable shift. But I can't see it breaking anything. Still, it's a better idea to do it when the vehicle is in steady-state.
Programming changes the reference points, thus creating a possible entry point to make mechanical changes. IE You are in one gear, select TOW HAUL, the transmission then recognizes the change noting it needs to change gears. It changes gear causing a potential increase in RPMs that the driver hasn't experienced.
Do what you want. It's your transmission. When I hauling/towing I drive in NORMAL MODE, if it seems I need to change I'll wait to change to TOW/HAUL as I described. There's NO GAIN to shifting in and out of different drive modes every few minutes.
I agree that there is no gain in shifting drive modes often... But I think using N is just as good as using T/H, maybe even better as far as depending on speed, the transmission just stays in in 6th instead of 7th or 8th, or 8th instead of 9th or 10th... Keeping/staying in a lower gear can be a good thing but if the truck can move the load in a higher gear that too is a good thing, but T/H wont allow it into those higher gears at certain speeds. JMO
I did not read anything about shifting in and out of different drive modes every few minutes and I certainly was not suggesting it.
When I read your comment "DO NOT do this with the truck under heavy load", I thought you were referring to the load placed on the engine/transmission when starting off or when climbing a grade. In this case, engaging tow/haul mode will just delay shifting to the next higher gear. There will be no sudden increase in RPMs. In the scenario you describe in the post above, an increase in RPMs would come from a downshift. This could occur if the truck was not under load when tow/haul was engaged (such as coasting) and tow/haul mode caused a down shift to aid braking. This could occur more suddenly than the driver expects.
