Tow Mode
Old Feb 22, 2013 | 10:58 AM
Courtney Williams's Avatar
Courtney Williams
Tow Mode
Is it ok to switch in and out of tow mode while driving or will it hurt the transmition? Never had a truck with tow mode just over drive.
Thanks!
Old Feb 22, 2013 | 11:14 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
NO problem... I use it ALL the time.... use it to slow down in town a lot too.
Old Feb 22, 2013 | 11:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can turn tow/haul on or off at any speed with no problems.
Old Feb 22, 2013 | 12:00 PM
Courtney Williams
Awesome, thanks. Seems kind of pointless to have it on going though the flats..
Old Feb 22, 2013 | 12:04 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Once you are over 55, it'll probably STAY in highest gear on the flat until you push down on the go pedal while in T/H. If you are towing, leave it there!
Old Feb 22, 2013 | 12:09 PM
Cowboy65's Avatar
Cowboy65
Tow haul mode still uses all gears in the transmission.
Old Feb 22, 2013 | 12:12 PM
Courtney Williams
Mine wont shift up in T/H unless I get into the 60-65 range. Today I was on the flat doing 55-60 and it wouldn't shift up. So I took it out of t/h and it up shifted and RPM fell to 1500 insted of the 2500 it was running in T/H and Boost dropped to 10 insted of 15 PSI. Truck seemed much happier there.
Old Feb 22, 2013 | 12:45 PM
MC5C's Avatar
MC5C
I do the same thing, I take it out of T/H when I am driving around at under 60 mph so it shifts up. That's when towing under around 10K, and on flat roads. I often would put it in T/H to get engine braking on a steep hill near where I used to live, meant I could go down the hill with only a tap of brakes at the bottom. At night I often turn it off because I slow down a bit and it shifts into fourth, and because the light bugs me.
Brian
Old Feb 22, 2013 | 06:27 PM
Ian123's Avatar
Ian123
I just recently started using it for hard stops, like when the a-hole in front of me slams their brakes for a yellow light. The engine braking really helps. I don't like it for driving though, I don't notice any difference in power from the gears being held for that extra 400 rpm.
Old Feb 22, 2013 | 08:11 PM
Misky6.0's Avatar
Misky6.0
Think of t/h as a semi-manual trans.
It tries to hold the gear when you lift off the gas
rather than let the vehicle coast freely,
Engine brakjng in a stick shift.
it also shifts up at higher rpms to keep the
engine from bogging down after the shift,
Since if towing heavy you'd want that.
mudfuel06
Modular V10 (6.8l)
Jul 9, 2012 08:43 PM
physmanics
Jun 15, 2011 07:52 PM
sppinner
Sep 29, 2010 08:17 PM
gwpowell
May 20, 2009 05:28 AM
Jeremy2792
Aug 3, 2008 03:50 PM
