Fuel System Elec. Problems
Old Oct 8, 2024 | 08:14 PM
SRB2's Avatar
SRB2
4th Gear
So I have a 2008 F-150 5.4 3V. The other day it died after starting up and running for about 5-10 seconds. Wouldn't start at all after that. Did the normal easy checks like fuses and filters. Have tried replacing the module and both sensors on the fuel system. Figured out that it will start and run(roughly) with the fuel pressure regulator that is located on top of the engine, unplugged. As soon as I plug it back in it dies. Local mechanic thinks there's a short somewhere. I spent quite some time checking all the wiring and haven't found anything.
Anybody have a bright idea or have had this happen before?
Old Oct 9, 2024 | 04:57 AM
techrep's Avatar
techrep
when you say module... do you mean FPDM ? what 2 sensors are you talking about ?
Old Oct 9, 2024 | 07:49 AM
SRB2's Avatar
SRB2
4th Gear
Yes sir, the FPDM, the fuel pump regulator, and then my mechanic tried a sensor that's on top of the fuel tank. Not sure what that one is called...
With the old or new regulator it still dies once it's plugged in.
Old Oct 10, 2024 | 04:51 AM
techrep's Avatar
techrep
not sure what the fuel pump regulator is ? never heard of an external one on our year trucks, There is a fuel rail pressure sensor FRPS on the fuel rail itself.
Old Oct 10, 2024 | 08:35 AM
SRB2's Avatar
SRB2
4th Gear
You are right, it is the FRPS that is causing the truck to die. My guy was calling it a regulator and I didn't think otherwise. So when that sensor is plugged in it dies.
Old Oct 11, 2024 | 04:35 AM
techrep's Avatar
techrep
do you have any DTC's ?
Old Oct 15, 2024 | 05:34 AM
trademun's Avatar
trademun
7th Gear
Interesting. I will try this on a 2004. The frame (near-axle) mounted module registered as a fault. i replaced it three (3) times to no help so I have direct wired both sides of it's feed. This is not a solution as the gas gauge won't work now and engine speed is limited. Tomorrow, I'll try what you suggest.
Old Oct 17, 2024 | 09:01 AM
redfishtd's Avatar
redfishtd
Look at gasket inside fpdm module plug it rolls and pushes plug apart ,pull it out and throw it away mines been gone for 15 years .. Use contact cleaner in plug pins . Clean the ground on rear axle it runs the fuel pump . In fact the fpdm switches that ground on and off to control fuel pump .
Check big connector under drivers side that wires run to the rear thru get mud out and clean with contact cleaner. Use electronic type contact cleaner ,other stuff can damage connectors .Look under drivers side there is a plastic cover over connector , It is bad about mud etc getting jammed in there.
To bypass fpdm for test you jump pins 2 to 3 on fpdm .
Old Oct 19, 2024 | 03:24 PM
trademun's Avatar
trademun
7th Gear
Thumbs up fantastic
I don't find any gasket. The rest of the post is "spot on." You have done great. Thanks.
fosters0440
Feb 12, 2024 02:38 PM
Sprint350
6.7L Power Stroke Diesel
32
Feb 13, 2022 07:46 PM
gwcon
6.4L Power Stroke Diesel
30
Nov 9, 2011 06:26 PM
vbsaltydog
1997 - 2003 F150
22
Oct 20, 2009 10:34 AM
javi2001
Dec 30, 2007 07:54 PM
