Confident this has been discussed on here probably many times but i just purchased a 2022 F350 6.7 And would like information on the fuel system problems that seem to be a serious issue on some vehicles. has this been resolved? Or is it still an on going problem? Is there something i can do to prevent this. Apparently the complete fuel system has to be replaced when it happens.
Okay seeing how you're new here, I'll help you out. My searching terms were not working well, so I went back by hand and found the links I knew were there.
The answer is as simple or as complex as you'd like it to be.
The simple answer is to buy fresh fuel from stations with high turnover. Drain your water-separator monthly. Change your fuel filter on schedule. Make sure not to accidently introduce gasoline, DEF, water, or any other contaminant into the fuel system. This is the most common cause of serious fuel system damage. Most owners do nothing more than this (and many do less with regard to water separator and filters) and never experience any issues with their fuel systems.
The next step is to use a fuel lubricity additive. There are dozens, and a lot of discussion about which is best. I use Ford's PM-22 in every tankful. Some folks think that any additive is a waste of money, others like the peace of mind.
The most complex answer is to install "disaster prevention kits", entrained air removal kits, etc. There are a few advocates of this approach on this board, but these folks are in the tiniest minority of Ford 6.7L owners. I'm sure that they will be along soon to make the case for these add-ons.
preventive measures include adding additives to add lube value...emulsify (or deemulsiy) water, anti gel (seasonal), etc.
mitigation factors include disaster prevention kits which spit the injector and roller bearing fuel paths.
gaps in the strategy exist in such cases where some stations have been known to pump gasoline instead of diesel which will destroy the pump. there are no detection systems for this. all you can do is a roads side flashpoint test on a sample of the fuel.
it is interesting how a lot of folks claim this is not a problem while at the same time there are folks posting their horror stories on the forum related to this.
Failure rate: https://www.hotshotsecret.com/lx4-pump-saver/
1% European Failure rate vs 7% USA because:
"The European EN-590 diesel fuel has a wear scar diameter 460-micron specification while in the U.S. the base is 520-micron in ASTM US D-975."
Take away is if you don't live in a state with Biodiesel requirements or availability, get anything 10 and up as that will reduce your scar diameter to 460-micron thus reducing the failure rate to 1%.
Beyond that, as others have said; pick high-quality fuel stations with a lot of traffic, drain the water separator regularly, and if you want get a disaster prevention kit.
Also, monitoring fuel rail pressure might help you catch a failing HPFP. Sometimes the truck will give you a low rail pressure code and if you act fast you will only need to replace the pump. On my previous engine, I got a low rail pressure code, replaced it after consulting a Ford tech buddy, and had no issues.
Enjoy your new truck.
What he means by that is an Air Dog, Fass or AFE unit that will remove the air out of the fuel that gets introduced into the fuel tank from the very movement of the truck. Like additives, some think this isn't required. When I looked into diesels, it seems that because of the lower pressure those fuel systems were using, air couldn't have had as bad of a detrimental effect like now with the pressures our engine fuel systems are using. Those injectors lasted longer. I have an Air Dog that I have to install. If it's a long term truck for you, one in which you'll be keeping after it's paid off, you could have a look into them.
i don’t think the folks who have posted being victims of cp4 failure would agree.
How many out of the hundreds of thousands of diesel Super Duties is that? How many out of all the millions of CP4 pumps out there across the brands is that? Again, it's an Internet problem. Diesels aren't for everybody. Some folks are just too neurotic to maintain their perspicacity.
The S&S Gen2 DPK is a very nice kit and is only $400. $400 is pretty cheap insurance for a fuel system that can cost close to $10000 to replace. The DPK also cuts downtime drastically if the HPFP does go out and needs replacing.
There is no way that the failure rate of CP4 pumps in the USA is 7%. If that was the case every car & truck manufacturer that used them would be out of business. I live in an area of Texas where 6.7L Ford Superduty Trucks are among the most common vehicles on the road. There are thousands of them and it is the top selling vehicle at the local Ford dealership (or at least it was when they were available...). I know dozens of people who have driven them for years, without a single fuel system related failure. Millions and millions of miles. Most have no idea that these "widespread" fuel system failures even exist. The couple of failures that I've heard of in the region were from careless mistakes like adding gasoline or DEF to the fuel. And in one instance a probable case of mixed diesel/gasoline from a fuel station.
Maybe don't take as gospel the marketing literature of a firm trying to sell you their particular fuel additive.
I know that lubricity is key but that doesn’t change the fact that the CP4 is a crappy design. I’m not taking any chances and ordered a S&S DPK this week.
