2019 F250 XLT backup camera issues
Still having issues. I did give the 2 connectors at the hitch a good coating of di-electric grease, removed them and the larger connector drained water out.......I saw a youtube video where a guy did away with those 2 connectors using waterproof butt connectors there and all his problems went away. Next warm day that is getting done.
The wires between the 2 harnesses at the hitch appear to match up, so I may splice those. The harness that passes through the tailgate and plugs into the harness going directly to the camera and tailgate lock dont match up at all.....
Well I am out of ideas. I eliminated the 5 wire connector at the hitch by splicing (soldering heat shrink connectors) https://www.ford-trucks.com/forums/1...or-delete.html and the camera worked for 1 day. This morning, more of the same ole same ole. Drove to work, camera fine. Drove home and its glitchy, but clear.
Well now I am not so sure it isn't a connector on the backside of the APIM.....went to reverse into my spot at work today and it was very grainy as usual, but I slapped the top of the dash above the screen and it went clear! Time to take it all apart and reseat the connections.
Well I may be a victim of my own demise. Took the sync system apart, re-seated all the connections, taped the yellow video connector and for 3 mornings and every single time I have been in reverse, perfect, no flickering even the slightest bit. I upgraded the 4.2" screen to SYNC 3.4 a couple years ago, so maybe the video connector vibrated loose slightly. That would explain the camera clearing up when I released the e-brake (or at least flickering of a different type) or when I banged the top of the dash. Good grief this has all been so frustrating.....
Summers22
Nov 26, 2023 02:28 PM
rokbrigade
Feb 25, 2018 10:04 PM
