198 axle codes
Old Aug 31, 2024 | 01:19 PM
triorez25's Avatar
triorez25
16 80/87 3.50 3.75M Ford Non-locking
3.75M means it's a 3750lb rated axle which is what your tag says also. That is a lighter duty axle which your tag also confirms. Your VIN indicates this is a light duty f250
alright that clears up a lot though i would imagine it's a very light duty f250 since the vin says it's a f150
Old Aug 31, 2024 | 07:23 PM
Franklin2's Avatar
Franklin2
I miss-spoke. The rearend code said it could be a heavier f150 or a lightduty f250. The VIN of course tells you what it really is. I am guessing the same rearend you have could have 5 lugs and be in a f150, or have 8 lugs and be in a light duty f250. By the way, Ford never called it a "lightduty" f250. They called it a F250 and then the heavier f250 was called the f250HD.
Old Aug 31, 2024 | 07:30 PM
triorez25's Avatar
triorez25
Alright makes sense this trucks seems to have been optioned out as a work horse. Though it never got a hitch aside from the bumper pull.
Brad Brown
Jan 19, 2022 08:30 PM
wharthog
Large Truck
Jun 9, 2021 08:02 PM
byro01
Jul 12, 2009 06:48 AM
lardman
Mar 17, 2005 01:21 PM
buffaloboy123
Oct 10, 2004 09:23 PM
