I have a F7 axle in my 1963 N600 truck, I have searched till I'm blue in the face, both on google and the old decode list at the top of this page. Anybody have specs on this axle?
F7 = Eaton model 13802 Two Speed Rear Axle / 5.83/8.11 / 15,000 lbs. Rear Axle Capacity
Does that make sense for your truck? You should have the 2 speed shifter or other evidence of the two speed like the shift motor etc on the axle, and your GVWR is probably under 20,000.
Thank you. How in the world did you find that so fast. I have been searching for two hours. Yes I would think so it has a 20000 rating. Yes I have the two speed axle, I was looking to see what the ratio's were and the weight rating. Thanks again.
