Lets Get Engine Going!
Old Sep 1, 2024 | 05:44 PM
  #46
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
That is a good starting point. There should also be a power wire somewhere to the key switch which is on your hand written paper diagram.
Old Sep 1, 2024 | 06:38 PM
  #47
red21sweep's Avatar
red21sweep
Thanks again for all help. The third wire from the ignition switch does to this "junction" type box. This is the power wire. What is the function of these "Junction" Boxes of wires.
Old Sep 1, 2024 | 06:45 PM
  #48
bmoran4's Avatar
bmoran4
The thing in your hand appears to be the circuit breaker assembly which is customarily attached to the gauge cluster:
Old Sep 2, 2024 | 09:13 AM
  #49
Truckfarm's Avatar
Truckfarm
That other thing looks kind of like a headlight switch without the pull ****?
Old Sep 2, 2024 | 10:05 AM
  #50
red21sweep's Avatar
red21sweep
I drained the oil and removed the oil filter cartridge. Should the oil in the housing have drained? It still have oil in the housing. Is there a plug in that as well or do I need to suck that out? Or maybe there is sludge and clogged?
Old Sep 2, 2024 | 10:14 AM
  #51
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I use a turkey baster to suck out the oil in the cartridge housing.
Old Sep 2, 2024 | 11:46 AM
  #52
red21sweep's Avatar
red21sweep
Was able to get oil out of oil filter housing with oil extractor. Took off front wheel. Brake pads expand when I press the brakes. Brake pads seem ok. Anything else I can do while I have the the wheel off. Can I spring the interior with wd 40?
Old Sep 2, 2024 | 01:01 PM
  #53
52 Merc's Avatar
52 Merc
Big fat NO on WD40 in the brakes. You don't want anything that would contaminate the brakes or eat seals with distillates, oils or silicones or anything slippery. If you want to clean up in there, you can use a garden hose (let it dry thoroughly before reassembly) or compressed air if you're sure the brake dust is asbestos free.
Old Sep 2, 2024 | 02:45 PM
  #54
red21sweep's Avatar
red21sweep
After testing the brakes I couldn't get the brake shoe back on. Took me a little time to figure out and get it back on put I did.
Old Sep 2, 2024 | 04:01 PM
  #55
PLM1955's Avatar
PLM1955
I'm really looking forward to the first engine start. You might want to video the event. Good luck with your truck!
Old Sep 2, 2024 | 05:24 PM
  #56
red21sweep's Avatar
red21sweep
What were these holes for. I assume the top was for a spot light?? What might the bottom been for? Also what would be the bestt side view mirrors for this truck?
Old Sep 2, 2024 | 07:25 PM
  #57
abe's Avatar
abe
I'd say the top was for a spotlight like you said. The bottom might have been for an antenna.
Old Sep 2, 2024 | 07:37 PM
  #58
bmoran4's Avatar
bmoran4
There is a good mirror discussion in this thread that shows what was stock and some ways to get close to that: https://www.ford-trucks.com/forums/1...l#post21097374
You can also make a request list for the great parts safari here: https://www.ford-trucks.com/forums/1...ts-safari.html
Old Sep 15, 2024 | 11:36 AM
  #59
red21sweep's Avatar
red21sweep
Haven't had much time to work or think about the truck but I would like to add a front bumper. According to the pictures what would I need?
Old Sep 19, 2024 | 12:08 PM
  #60
52 Merc's Avatar
52 Merc
Underneath all that rust, poor patching and bondo should be a seam between the lower fender and the gravel valance, with a notch for the frame horn end to protrude through, that the bumper would bolt to. You'll need to make the repairs and unmodify the damage in the sheet metal, and repair/replace the frame ends, or make some other suitable bumper bracket, to install a bumper.
