Lets Get Engine Going!
Old Sep 19, 2024 | 12:15 PM
  #61
red21sweep's Avatar
red21sweep
Are the these part of the trucks frame? It looks like they were cut off on mine.
Old Sep 19, 2024 | 12:21 PM
  #62
52 Merc's Avatar
52 Merc
that is correct
Old Sep 29, 2024 | 06:03 PM
  #63
red21sweep's Avatar
red21sweep
I made a Fall display with the truck. I added temporary lights for head lights for the display.
Old Sep 29, 2024 | 07:18 PM
  #64
abe's Avatar
abe
That looks great!
Old Oct 3, 2024 | 03:30 PM
  #65
red21sweep's Avatar
red21sweep
What it this bolt on the engine. I do not see it on photos online.?
Old Oct 3, 2024 | 11:00 PM
  #66
ALBUQ F-1's Avatar
ALBUQ F-1
That would be right in the middle of a coolant port on the block, so someone may have drilled and tapped a hole for a temperature gauge. I bet the chrome part is just a slip-on cap over a hex head bolt.
Old Oct 4, 2024 | 06:19 AM
  #67
red21sweep's Avatar
red21sweep
It is on both sides if that matters as well.
Old Oct 4, 2024 | 07:31 AM
  #68
Hammermanr2's Avatar
Hammermanr2
Well if it was for a gauge, the right way to do it would be a dual gauge or two gauges since each side has its own cooling system.
Old Oct 4, 2024 | 02:38 PM
  #69
ALBUQ F-1's Avatar
ALBUQ F-1
Might also have been for a block heater.
Old Oct 4, 2024 | 02:46 PM
  #70
red21sweep's Avatar
red21sweep
I am off today so I was surfing the net with all the great videos on F1s on youtube, "Will it start?" and "total refurbs". I know I am jumping ahead but I would like to put a wood liner in the truck bed. The bed panels, tailgate are pretty rough. I see you can buy a "Brand New" truck bed, panels, rails, tailgate online. Thoughts on the condition of that for my truck apposed to having someone repair the rusted out places.
Old Oct 4, 2024 | 05:16 PM
  #71
52 Merc's Avatar
52 Merc
My 2c, fwiw, is buying a new bed will be some of the best money you can spend on your truck. For a couple of grand, basically half of the bodywork on your truck is done. You can't buy the materials to get your old parts to the condition new metal is, let alone the massive amount of labor involved in rust repair, hammer and dolly work on both sides of the sides, filler and block sanding both sides of the sides, priming and block sanding over and over again both sides of the sides, arrrrgghhh. Do I need to say more...?
Old Oct 5, 2024 | 06:59 AM
  #72
red21sweep's Avatar
red21sweep
Is there any welding involved in instaling this?
Old Oct 5, 2024 | 11:11 AM
  #73
52 Merc's Avatar
52 Merc
The bed ad says kit, and the subframe rails are sold separately, so I would say yes, there is going to be welding involved with these parts shown. I have seen complete assemblies sold, but that, obviously, will increase the price of the part and the shipping. It's still well worth it especially if you don't have the talent or equipment to assemble the kit.
https://www.ecklers.com/1948-50-ford...8-66102-1.html
If you can live with the later style flat panel sides instead of the correct for 48-50 raised panel sides, you can save about $1800.
https://www.ecklers.com/1950-52-ford...8-13137-1.html
Old Oct 6, 2024 | 08:58 AM
  #74
red21sweep's Avatar
red21sweep
I spoke to company. It is bolted together no welding.
Old Jan 20, 2026 | 09:12 AM
  #75
red21sweep's Avatar
red21sweep
Originally Posted by bmoran4
That is a good starting point. There should also be a power wire somewhere to the key switch which is on your hand written paper diagram.
Going through old threads:
8 cyl negative ground 12V with a generator.
@bmoran4 The "power wire" you mentioned last year missing from my photo of the wires. Would that come from the battery terminal on the solenoid to the ignition switch? Or do I not need that with the new Fuse Panel?
Also, should the battery connect directly to the B Terminal on the Regulator?
