Fuel System Cleaner?
Old Aug 30, 2024 | 08:46 PM
ag-ford-4x4's Avatar
ag-ford-4x4
Originally Posted by tbear853
Come to think on it, I think I did that very thing. I know it was a stock 2bbl when bought in May 1986, but the carb needed work, and I had this Holley already, so a Mr. Gasket adapter was used for a few months, then I think maybe was following Spring in 1987 I did the intake as I did the cam. You are right, it did just fine.
what model of carb should I get and what spacer?
Old Aug 30, 2024 | 10:06 PM
tbear853's Avatar
tbear853
Mr. Gasket 1933 Mr. Gasket Carb Adapter (holley.com) is the adapter I used then, it was Mr. Gasket before Holley bought it. In my case I used a Holley "List" # 1850 4 barrel 600 cfm carb I had and knew I was gonna use anyway when I put an intake on, just was no need for me to rebuild the stock 2 barrel carb then. The 2 barrel is not a difficult one to rebuild.
If your truck is an automatic, you'll need to extend the transmission kick down link with a kit too. If funds or time are tight, might be best to rebuild your 2 barrel with new gaskets and accelerator pump and power valve for now.
Old Aug 30, 2024 | 10:11 PM
ag-ford-4x4
yeah, I can rebuild this for 28 bucks and do it in about 1 hour start to finish. I already have it torn down waiting for the parts house to open tomorrow. I’ll do that and make sure she’s running good before doing your upgrade but I think upgrading is a good idea.
Dale72F250
Aug 13, 2024 03:51 PM
John Gomoll
Aug 6, 2023 12:51 PM
tjc transport
Jun 22, 2012 05:04 AM
RangerHaywood
Jun 8, 2010 07:29 PM
lwhitcomb
Dec 7, 2005 12:18 PM
