cleaning fuel system
Old Apr 29, 2012 | 07:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
i went to move the 2000 yesterday and it will not start because the gas went bad .
it has been sitting about 6 months, since it did not snow this past winter.
how do i go about cleaning the fuel system?
i was thinking suck the gas tank empty with an electric fuel pump, and blowing out the lines with air. does this sound rite?
Old Apr 30, 2012 | 07:49 AM
subford's Avatar
subford
I think I would look someplace else beside the fuel that is in the tank.
I have trucks here that has two year old fuel in the tanks and they run OK but maybe not 100%.
Old Apr 30, 2012 | 07:50 AM
tjc transport
i ain't rite
it is definitely the fuel. it smelled like varnish when i emptied the tank.
this ethanol blend is pure garbage.
Old Apr 30, 2012 | 12:03 PM
tjc transport
i ain't rite
well, it's alive again. 7 gallons of stale gas out of the tank, and 3 hours to purge the lines. it finally started. i put 1 half pint of seafoam in the i gallon can the fuel pump is in, and let it run for 3 minutes to circulate the seafoam. it is now sitting to let the seafoam do it's magic.
Old Apr 30, 2012 | 05:59 PM
Beechkid's Avatar
Beechkid
Yup- at 6 months fuel turns to varnish....IMHO, I add MMO (marvel mystery oil) to the fuel (cars, toys, lawnmover, etc.) and never had a problem.
Old Apr 30, 2012 | 07:11 PM
tjc transport
i ain't rite
i normally put marine stabil in, but must have forgotten the last time.
Old Apr 30, 2012 | 07:20 PM
LxMan1's Avatar
LxMan1
Reformulated gas is crap. Lower mpg and goes bad in about 4 months or so. We have it here in our county, so I usually fill up 14 miles down the road in the next county with 100% real gas.
Old Jun 22, 2012 | 05:04 AM
Ed's Avatar
Ed
Also, I add a bottle of Stabil now as part of my normal fuel maintenance, once a month, and a bottle of IsoHEET Dry Gas. Never a fuel problem. Also, occasional doses of Marvel Mystery Oil are excellent, as it has a light lubricant that helps lube anbd keep clean modern in-tank fuel pumps.
Lastly, keep your gas tank at least half full at all times. Running your tank at 1/4 full or less causes your fuel pump to run HOT. Gasoline acts as a coolant for fuel pumps, and from the half level to full (preferably) the pumps run cool = long fuel pump life.
Lastly, modern gasoline with an ethanol blend is pure crap. It cuts fuel mileage by up to 15% and shuns peak engine performance. Thanks to our federal government, but when have the feds ever cared about the people that they are supposed to represent?
maclif
34
Oct 12, 2016 11:44 PM
RdnckEMT25
Oct 28, 2010 10:32 AM
Charlie Bravo
Apr 23, 2010 12:20 PM
redfoley
Jun 23, 2003 07:37 AM
torquemeister
Mar 14, 2003 02:47 AM
