1997 E4OD Transmission Shift Problems
Thank you for the continued dialogue with me on this issue.
Typically, sensors only send out sine waves. They are just magnets that watch a piece of metal go by. That metal causes the magnet to make some voltage. Yes, I am being very simple but that is how my brain works. There are many other electrical engineers that can explain it better than me.
I stand by my original statement. The PSOM changes the VSS sine wave to the 'digital' square wave signal.
Craig
The symptoms: Erratic hard shifts, both up and down. The truck at random would "pop" into a nuetral type state of operation. The transmission would also stretch out first to second up to 3,000 rpms, then slam second gear hard! I could shift the truck with easing up on the throttle but it still hit gears hard!
Other symptoms include transmission not down shifting properly when coming off the freeway (would stay in high gear and "lurch" at the stop sign), and would also either stay in higher gear when rounding a corner or sometimes pop into the "nuetral" type mode.
The VSS (vehicle speed sensor) tested good and the speedometer still worked during all of this. This really threw me off because everything I have learned is if your speedometer works, your VSS is good.
I had my solus pro hooked up to the truck and noticed when the transmission acted up, my speed dropped to zero on my test equipment but not the dash board.
I ohmed wires to the RABS module, and they were good. So I did figure the problem was between the speedometer and the pcm (but I thought it was a bad wire only). But I was off a little bit. I learned with help from Mark Kovalsky on this forum that it was the PSOM module. I found a local guy that tested mine, yep it was bad....rebuilt it and re-installed tonight. Truck drives, shifts, has power like it has not had for a while.
All this said, remember this problem was "intermittent" which made it tough to figure out. Hats off again to Mark on this forum. Hope this helps!
Suddenly, An ARMY Descends, an Army of BaddAss Skilled Motor Heads , Do it Yourselferz with good input, and so on..
. The Vehichles Owner becomes enveloped by People who Selflessly want to Help. Plus the Challenge , Education, Team Effort, and Sense of Accomplishment are always a Good Feeling....
I've seen threads go on with hundreds of hours and years of input..
. Regardless, It is Very Rare, that people show proper Respect and or Thanks for said input and help..
The Worst part... They ALMOST NEVER RETURN TO SAY IT'S FIXED AND THIS IS WHAT THE ULTIMATE ISSUE ENDED UP BEING...
You, My Good Sir... You were Great at explaining your issues, not leaving any aspects out due to FalsePride or whatever, which surprisingly keeps many from mentioning all aspects.. not that there was any issue with FalsePride here..
. You Explained Your Issue and Related. You took advice , Discussed it and proceeded to follow through with each stage and replied with results...
. Long post Short..
. You actually came back and Said it was fixed... and what the Gremlin actually was..
. Regardless of whether that is the fix for my car, It is Great to see someone Actually, Close The Case and Share the Information... Instead of Forgetting those who have participated in your journey..
. Thank You...
\m/
. Long post Short..
. Thank You...
\m/
