1996 f250 e4od with unusual problems
Old Oct 4, 2009 | 09:07 PM
scott0238621's Avatar
scott0238621
Hey guys see if you can help me out.
My 1996 f25o 7.3l has a tranny problem or maybe electrical problem.
When in OD it will sometimes disengage the torque converter clutch solenoid. I can ground it manually and it locks up fine. I don't know why I am loosing the signal.
Also, when in any gear other than OD the tranny will loose all forward motion - almost like it goes into neutral. If I stop and shift into park and then drive again it works fine. Also when It acts up - which isnt always- I can shift into low gear 2 or 1 ands drive just fine.
These problems happen at random. No common operating temperature, with or without a load.
I changed the pcm with another and the problem persists. No codes in the computer.
Other then when it acts up the tarnny works great.
Whats wrong?
Ive tried 2 tranny shops and they dont have a clue.
The mlps sensor works fine, the solenoids test fine and the vss test fine.
Old Oct 5, 2009 | 02:33 AM
Fomoko1's Avatar
Fomoko1
Hi Scott, great to have you on board.
Help is in the 1994.5 - 1997 7.3L Power Stroke Diesel tech forum: 1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Oct 5, 2009 | 10:02 AM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.
Jordanjc
New Member Introductions
Oct 28, 2014 08:52 PM
