Drop down battery boxes
Old Aug 10, 2024 | 08:34 PM
bobscogin's Avatar
bobscogin
My '53 F100 has a 12 volt battery mounted on the firewall. I want to install a frame mounted "drop down" battery box. Recommendations on location, brand? Thanks --
Old Aug 10, 2024 | 09:23 PM
jniolon's Avatar
jniolon
old and in the way
Mine is mounted on the frame rail between the running board brackets on the pass side.. My truck sits low, so getting to the battery is impossible without a lift or a floor jack and jack stands.. Plus it's heavy and this old man with bad shoulders
can't do the weight... so I made a bracket that attaches to my floor jack to lower and raise it...more inconvenience . I wouldn't do it again. Seemed like a cool idea BEFORE installation. I added charging terminals in front of the front cab mount
for the trickle charger and jumper cables if needed.. here's mine home made from 1/8 stainless plate.
john
UNDER FRAME SLIDE DOWN
Old Aug 11, 2024 | 03:17 AM
1949f1's Avatar
1949f1
I too mounted a drop down box just under the cab. Like John i have a bad back and used a floor jack to raise it up into the lock position. My charging terminals like John's are just under my running board
Old Aug 11, 2024 | 06:45 AM
scot6687's Avatar
scot6687
4wd Low
john
I like your idea of the charging terminal any part numbers ?
Old Aug 11, 2024 | 09:02 AM
jniolon's Avatar
jniolon
old and in the way
nah...just generic ebay parts... also get them at local racing or auto parts store
j
Old Aug 11, 2024 | 09:04 AM
56panelford's Avatar
56panelford
Amazon Amazon
Old Aug 11, 2024 | 09:55 AM
scot6687's Avatar
scot6687
4wd Low
Ok, thank you! Keep on trucking!!!!
Old Aug 11, 2024 | 11:30 AM
CharlieLed's Avatar
CharlieLed
I opted for a drop-down battery box in the original battery location...this leaves me the option of accessing the battery from the underside of the truck or through the OEM access panel under the carpet.
Old Aug 11, 2024 | 11:39 AM
bobscogin's Avatar
bobscogin
Makes sense. Good idea. Your box appears to be stainless steel. Do you recall the source?
Old Aug 11, 2024 | 01:23 PM
CharlieLed's Avatar
CharlieLed
It is stainless...I won it at a truck show raffle, not sure about the brand.
Old Aug 11, 2024 | 02:54 PM
M2HB's Avatar
M2HB
I used the No Limit Engineering drop down battery box.
I do not have my cab back on yet so I do not know if it will clear without jacking up the truck. I am still going to use the original battery opening in the floor, if necessary. I also ran large welding cables to battery lugs under the hood for jumping the truck and hooking up engine electrical systems.
The PO had installed a battery on the right inner fender and it did a lot of damage.
Old Aug 12, 2024 | 06:36 AM
CharlieLed's Avatar
CharlieLed
After a little researching, I find that my battery box is made by No Limit.
Battery Box (nolimit.net)
superman64011
Mar 14, 2024 01:05 PM
blake in spokane
Jan 1, 2023 06:59 AM
Thenewboss
All Things Towing
16
Oct 3, 2014 09:55 AM
kaptainstingray
18
May 13, 2012 04:22 PM
Caddy 53
May 1, 2002 07:26 PM
