Drop Down Battery Box ?
Old Dec 31, 2022 | 04:29 PM
blake in spokane's Avatar
blake in spokane
Getting ready to mount my drop down battery box. Is there any particular measurements, battery cable routing I need to consider or allow for ?
Old Dec 31, 2022 | 09:02 PM
jniolon's Avatar
jniolon
old and in the way
batteries under running boards are inconvenient to access from the ground...especially with a low truck
just make them long enough that you can let the box down completely without the cable to the solenoic binding.
are you going to put some jumper/charging posts somewhere convenient ??
here's what I did
https://jniolon.classicpickup.com/ba...batterybox.htm
Old Dec 31, 2022 | 10:15 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Good comment above from John. I installed a drop down box attached to the right frame rail. When I went to install the battery into the box, I actually had to use jack stands to raise the vehicle enough to crawl under the running board and use a floor jack to lift the battery high enough t drop into the box. I have jump start posts under the hood in case they are ever needed. They also double as trickle charger connections. My drop down box is from a 2003 Econoline aux battery that was used on very few Econolines.
Old Jan 1, 2023 | 01:27 AM
1949f1's Avatar
1949f1
I also put mine on the inside of the frame just behind the cab on the right side. My charging post are just under the right running board.
Old Jan 1, 2023 | 06:59 AM
jniolon's Avatar
jniolon
old and in the way
Joe, same here... I actually fabbed up a "lift thingy" that attaches to my floor jack to raise the battery/tray up to it's ride position. 75 years and two bad shoulders
and a 40# battery do not work well together.
and ditto on low rides...jackstands are your friend.
I put my charging posts on the front cab mount.. easy to access with full tilt hood.
5851a
All Things Towing
17
May 3, 2021 10:23 PM
bjmayberry2
13
Mar 19, 2016 02:53 PM
grafekie
All Things Towing
Jul 20, 2007 06:23 AM
FordFadgeole
Feb 21, 2004 03:43 AM
Taumac
Jun 17, 2003 03:33 PM
