Dash help
Old Aug 10, 2024 | 05:08 PM
Lt.Redbeard's Avatar
Lt.Redbeard
4wd Low
Dash help
So I currently have the dash out of my 92 f 250 chasing down wiring issues. While it is out I am looking to reseal the vents since it is all accessible. What is everyone using to seal the vent up because I am not finding much as far as replacement foam. Is this just something to use a generic foam insulation on or more specific.
if this question has already been answered a million times I apologize.
Old Aug 10, 2024 | 05:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Honestly, I am not sure what you are asking. The heater box gets its air from the cowl area under the wipers. What dashboard vents are you looking to reseal?
Old Aug 10, 2024 | 06:16 PM
Lt.Redbeard
4wd Low
These foam seals that stick to the back of the dash and seal to the heater box.
Honestly don’t know what they are “technically” called.
Old Aug 10, 2024 | 08:52 PM
My4Fordtrucks
I would measure the dimensions and then see what is available with an adhesive backing. I can usually find something like that on a roll from McMaster-Carr.
Old Aug 10, 2024 | 09:16 PM
Lt.Redbeard
4wd Low
Thank you for the help
Old Aug 11, 2024 | 06:06 AM
manicmechanic007's Avatar
manicmechanic007
Home Depot has a big selection of stick-on foam like that
Also, parts stores have the heavier duty kind for a camper shell to bed interface
Old Aug 11, 2024 | 02:06 PM
Duke5A's Avatar
Duke5A
This place has every kind of foam imaginable: https://www.thefoamfactory.com/
I've used them for hood scoop seals and even gas tank insulator pads. They have everything.
Old Aug 11, 2024 | 03:15 PM
Hit Man X's Avatar
Hit Man X
Slick link. In the past I have just used that stuff from Ace Hardware, but something more durable seems great.
Old Aug 11, 2024 | 09:31 PM
Edd505's Avatar
Edd505
yep I carry some in my RV for the basement doors etc.
Green72F250
Jul 10, 2014 11:35 AM
spoolen&smoken
6.4L Power Stroke Diesel
Apr 12, 2013 11:08 AM
squeals99
Appearance & Dress-Up
Jan 9, 2007 08:42 PM
pward76
Feb 9, 2003 07:31 PM
