Oof
Old Aug 2, 2024 | 10:31 PM
arnegrant's Avatar
arnegrant
Oof
1979 F250 400 4x4 C6 was running so good. I got a wild hare and decided to enter it in the county fair truck pull. Fabbed up a hitch, was on my way to wash the truck and go and pay my entry fee and loss of power 1-1/2 hours before the registration going down a road 55 mph.
Limped It on the shoulder to a gas station a mile down the road.
Temp ok. Oil pressure ok. Wont go more than 2 mph, dies constantly.
No fuel in clear filter, some bubbles coming through it when the truck was off, maybe boiling? Topped it off with gas, wondering if I vapor locked it.
It was like 95 degrees out.
Messed with it for an hour. Got fuel in the bowl again but it doesn't do anything but idle bad now, no power at all.
I am thinking it maybe took the coil out? Let it cool down for a couple hours and tried again but no luck.
Idles poor, backfires when I give it any fuel.
Will check the spark when I got time.
Monday the guys will be like - how did the pull go, and hopefully I don't have to tell them my truck blew up on the way to the pull. Shoot.
Old Aug 3, 2024 | 07:02 AM
egchewy's Avatar
egchewy
clogged fuel system/carb? crack in vacuum cap/hose?
I did an oil change in a mercedes 85 380sl and ran like crap after. Couldn't understand how an oil change would affect starting/idle. I changed the fuel filter w/ no difference.
happened to take off the air cleaner one day and noticed that a 3 way vacuum "Y" had somehow come undone from all 3 hoses going into it. not sure how this came undone during a routine oil change.
plugged it back in and ran like a top.
Old Aug 3, 2024 | 08:34 AM
NM76F150's Avatar
NM76F150
Backfires? I’d suspect ignition.
Old Aug 3, 2024 | 09:44 AM
beartracks's Avatar
beartracks
Might have jumped time.
Old Aug 4, 2024 | 10:08 AM
FuzzFace2's Avatar
FuzzFace2
I was thinking the same thing.
How many miles on the chain?
Pull #1 plug and crank it with finger overe plug hole till it gets pushed off.
Turn the motor by hand to TDC and pop the dist. cap where is the rotor pointing?
If not at #1 or even 180 off the chain jumped.
Maybe the dist. hold down came loos and the dist. turned if you are lucky.
Dave ----
Old Aug 4, 2024 | 08:43 PM
XSoph's Avatar
XSoph
ICM can act weird up to the moment it finally dies. Heat eventually cooks all of them. Some will kinda work after they cool off, but once they start to go they have to be replaced. Most Autozone locations have a machine to test the ICM for you.
If you are gonna keep the stock duraspark setup, always keep a spare ICM in the truck and get NOS if possible. The aftermarket replacements are trash.
Old Aug 5, 2024 | 07:10 AM
jflem's Avatar
jflem
I agree with swapping in your spare ICM to eliminate that.
Old Sep 21, 2024 | 01:44 PM
arnegrant's Avatar
arnegrant
Broke roll pin on the distributor shaft
Old Sep 21, 2024 | 03:49 PM
5851a's Avatar
5851a
3 times in my life, 1 was chunk of nylon timing chain. 2 was bought 77 T-bird from salvage yard that had fresh ignition parts and forgot roll pin under in star wheel, big backfires. 3 was 1 strand of wire brush sucked up in oil pump. 1st time it took teeth off distributor gear and camshaft. Bad things happen at the worst times.
Old Sep 22, 2024 | 07:11 AM
Albeix's Avatar
Albeix
Backfires can also be caused be an excessively lean mixture!
Ronnief150man
Apr 16, 2018 04:15 AM
f350rebel7788
Nov 23, 2011 11:40 AM
poffutt
1978 - 1996 Big Bronco
Aug 30, 2011 02:04 PM
nobodyspecial
127
Dec 18, 2007 06:49 PM
Big Sky
Modular V10 (6.8l)
Jan 21, 2005 09:51 PM
